Old 03-22-2010, 10:37 PM   #1
jaimico
Drives: yaris advance
Low rpms with a new battery
Yesterday my 2008 yaris sedan battery just past the way, and I replaced it with a bigger model (from 350 to 500 cca), since I could not find the same size or capacity as the original.
To my surprice, after replacing the battery, I started the car right away, but the rpms just when to the minimum, like 300-500 at idle (normally are around 700), it was like having a 3 cilinder engine, let it run for a while, but did not change, so i took it for a good run, and still the rpms where dropping at idle, and suddenly it just came back to normal.
Today i had my 50K maintenance, and when I came home disconected the battery to adjust the supports, and when I started the car again , the same problem again, but this time at a smaller rate (the rpms where around 500 know).
So, is it something with the car computer the need to adjust after a while, or what??, since the alternator was chargin normally.
jaimico is offline   Reply With Quote
Old 03-23-2010, 03:02 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The ECU is adaptive and it will adapt to your driving style. When you disconnect the battery the ECU will reset to default. After running a while it will adapt again.
Old 03-23-2010, 10:40 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Also, if the new battery wasn't fully charged, drawing heavy charging current could drag the idle speed down. I'd think the ECU would regulate the idle speed, but people notice fluctuations when the AC compressor kicks in and adds load...
Old 03-23-2010, 10:41 AM   #4
jaimico
Well that one is new, today I came back to normal, thanks for the tip.
Old 04-05-2010, 08:44 AM   #5
jaaf
jaaf's Avatar
Drives: Belta 2006 Sedan
I'm facing the same problem with my 2006 yaris sedan 1.0 after changing battery terminals.. if a good run will solve my problem too?
jaaf is offline   Reply With Quote
Old 04-05-2010, 01:40 PM   #6
TheSilkySmooth
TheSilkySmooth's Avatar
Its just the ecu relearn. thats all. No Problem - unless it NEVER comes back.
Old 04-06-2010, 11:12 PM   #7
jaaf
jaaf's Avatar
how much time ECU will take to relearn? because the problem is still there....
Old 04-08-2010, 09:35 AM   #8
kazama82
Drives: VIOS
few days..
kazama82 is offline   Reply With Quote
Old 04-08-2010, 06:17 PM   #9
jaimico
the more you use the car it will go away sooner, not just with a good run...!
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
FS: not a car... 2004 600rr low miles (SoCal) AdeJong 03 Cars for Sale by private party 8 09-25-2009 11:13 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
