Old 03-23-2010, 12:18 PM   #1
skoolafish
Drives: 2008 Polar White Yaris Sedan
A handful of extremely NEWB questions
ok - so i'm about to start shopping for the cheaper mods. i'm looking at air filters, fog lights, and a wing type dealy for my trunk
i have an 08 sedan
- i'm seeing both flat air filters and round ones. i already know i need a flat one because i've opened the housing and seen it. i assume the round is for an added intake, but i just want to be sure...?
- i have a choice between AFE and K&m...is there any reason to pick one over the other?
- does replacing oil filters do anything for performance? if so, which one should i get?
- when i first start him up in the morning, and get going, it feels like its struggling to pull off...kind of sluggish, almost like a parking brake is on but not that intense. any mods to remedy this?
sorry for the dumb questions but ya gotta start somewhere
skoolafish is offline   Reply With Quote
Old 03-23-2010, 12:20 PM   #2
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
your car isnt warmed up....
zachryboles is offline   Reply With Quote
Old 03-23-2010, 12:21 PM   #3
skoolafish
i understand that this is a myth and a waste of gas. plus it hasnt been that cold here for a couple of weeks
Old 03-23-2010, 12:41 PM   #4
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
i have an 08 sedan
1. Yes, flat filters are for the OEM airbox. If you go to the round (conical) filter you have to actually install an aftermarket intake
2. If you're going to stick with the OEM airbox, stick with the OEM filter. I don't think any of the drop-in filters make any significant performance difference. The only other advantage is the fact that they are reusable, but even that doesn't seem to make them worthwhile (in my opinion).
3. Oil filters likely make no difference. I'd stick with OEM or whatever other type of filter you like.
4. Just because the air temp isn't cold, doesn't mean that your motor isn't "cold". Motors and transmissions take a little bit to warm up. That's likely why the car feels a bit poky when you first turn it on
Old 03-23-2010, 12:54 PM   #5
severous01
any aftermarket air system is all about the same. it just depends on how much you wanna spend. i'd look in the for sale sections and buy the cheapest one or one that just happens to come up. it's all aesthetics, tehy all add the same amount of power, and they're all designed just about the same.
oil filters will not increase performance
Old 03-23-2010, 01:06 PM   #6
skoolafish
thank you all. i think ill just focus on my fog lights and wing for now then
Old 03-23-2010, 01:19 PM   #7
spoiler for ya.
http://shop.microimageonline.com/Yar...-U-spoiler.htm
Old 03-23-2010, 01:22 PM   #8
skoolafish
thanks. question for ya...what made you choose an underdrive pulley instead of another type?
pretty sure a pulley will be in my next set
Old 03-23-2010, 05:25 PM   #9
An underdrive as opposed to what? The NST CR Lite, the complete NST set w/ WP and ALT, or something else entirely?
I went with NST UD based on reviews and resale became available from another member. I didn't really want the 3 piece set as the 'bang' comes from the crank pulley. The other two are little more than cosmetic mods. Didn't need the CR Lite since I'm not s/c'd, nor do I have high electical power drains.
Old 03-23-2010, 05:53 PM   #10
H3LlIoN
Drives: '09 Yarrrr hatch
ok - so i'm looking for a wing type dealy for my trunk...
When i googled "wing type dealy" on google images, this is the only car related pic that was on page one. Therefor, I now demand that you put this exact "wing type dealy" on your car.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 03-23-2010, 05:57 PM   #11
H3LlIoN
One more thing, specific to the oil filter question...
Oil filter co's always tout their micron filtration, flow rates,etc...On an enhine this size with such a weak oil pump, it won't matter, so go with whatever you want. I personally prefer FRAM, but that's just me, and that's because the bottom two inches is rubber dipped to make gripping the damn things easier.
However, in high horsepower applications it can make a difference. I have literally seen an oil filter implode because of the vacuum created from the oil system that was being run, but this was on a big block nitro rail, not a yaris. My point is that yes, it can make a difference, but not on a yaris.
Toyota
Moving Forward
Old 03-23-2010, 06:54 PM   #12
skoolafish
lol...i will do no such thing. "spoiler", is it? lets roll with that instead...
thanks for the oil filter info
@ WeeYari, i meant the 10% underdrive as opposed to the cr lite or wp lite
Old 03-23-2010, 08:17 PM   #13
H3LlIoN
the 10% underdrive changes drive ratio, whereas the lite pulleys are same size, just lighter to make engine spool faster.
Toyota
Moving Forward
Old 03-24-2010, 08:30 AM   #14
skoolafish
awesome, thank you
new system tech questions ryota In Car Entertainment + Electronics (audio / video / alarm) 7 07-30-2009 04:09 PM
Going to Dealer, questions on options. ejaf New YARIS Purchase Forum 24 11-19-2008 02:05 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 01:42 PM
new owner.. have questions chibianh General Yaris / Vitz Discussion 8 05-14-2006 11:44 AM
