Old 03-23-2010, 06:07 PM   #1
yaris-one
Drives: 09 sedan, stock....for now
Need Some Help
For some reason my seat belt and airbag light for the passenger seat are on and wont turn off any suggestions?
yaris-one is offline   Reply With Quote
Old 03-23-2010, 06:23 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Check the seat pressure harness at the bottom of the seat... It got loose in my car once...
Old 03-23-2010, 08:40 PM   #3
The passenger Occupancy ECU is located right under the front of the passenger seat. It has two connectors plugged into it. Like TK said, check them. If neither is loose, check the 4 connectors up under the four corners of the seat. If that's not it, reply back and I can walk you through having the SRS system flash its light to tell you why it's not happy.
