Old 03-24-2010, 10:35 AM   #1
cast
Drives: 2007 hatchback
Help : door lock manual-power conversion
Hi,
I bought a keyless entry kit from Ebay. When I tried to install it, I realized that that kit was for powered door lock only which does not include any actuator. Since I can't return the kit, my questions are :
(1) if I get some aftermarket actuator, can I get it to work?
(2) If so, what type of actuator should I get?
(3) with the aftermarket actuator, where is the best position to mount it. I only plan to power the lock on driver's side.
My car is 07HB. The keyless entry kit is VIPER 211HV.
Thanks a lot.
cast is offline   Reply With Quote
Old 03-24-2010, 11:25 AM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
Viper sells actuators too, although your best and easiest bet is to just jack the OEM equipment out of a wrecked yaris and put it in place. It'd be the easiest thing to do, both from an acquisitions standpoint as well as mounting location.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 03-24-2010, 12:34 PM   #3
cast
It is almost impossible for me to find the a wrecked yaris in my area. So I guess I have to find the aftermarket actuators. But I don't know too much about this stuff. Not sure if anyone will work or I need to choose a specific one with certain size/shape.
Old 03-24-2010, 01:16 PM   #4
Check out this thread for a very similar discussion with info on the A-1 aftermarket actuators:
http://www.yarisworld.com/forums/showthread.php?t=26481
From Manual Window/Lock to Power W/L eocintron Cosmetic Modifications (Exterior/Interior) 5 11-10-2009 10:31 PM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Power lock conversion question mybabygirl DIY / Maintenance / Service 9 04-08-2007 07:47 PM
How many 5-speed manual with power package? abcando General Yaris / Vitz Discussion 11 08-01-2006 09:54 AM
