Old 03-25-2010, 02:03 PM   #1
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Rockford Fosgate 5.25"
I have some Rockford Fosgate 5.25" speaker that I would like to install in my 09 Yaris Sedan. What I would like to know is what will I need to install these into the front doors? I'd rather not hack things together to get them to fit.
Is there a set of brackets that I can buy so that I don't have to drill new holes into my door or into the stock spacers?
Thank you for the help I searched around but really couldn't find an answer to this particular questions. Just a bunch of people that say "go 6.5""
Reeves360 is offline   Reply With Quote
Old 03-25-2010, 02:12 PM   #2
If the sedan happens to be the same as my LB, then this is the hole that you are dealing with in the front doors. You will need an adapter ring to make a 5.25 big enough.
Also, you will not find an adapter or spacer that will line up with stock mounting screw holes. Using the OEM as a template, you could fashion one out of MDF.
Rockford Fosgate or Alpine? dccurrent In Car Entertainment + Electronics (audio / video / alarm) 2 03-16-2009 11:16 PM
1000watt Custom built fosgate Sub box id3379 Items for Sale by private party 0 11-30-2008 04:29 PM
