Old 11-18-2006, 04:39 AM   #1
ASHRAF
Scubie Du
Drives: '10 SWP STi/'09 Escalade
Send a message via AIM to ASHRAF Send a message via MSN to ASHRAF Send a message via Yahoo to ASHRAF
important question about 18's on a yaris (need some help)
Hi every body
I'm planning to buy some 18x7.5" Wheels for my hatchback Yaris
i heared that the Yaris come along with TRD 18*7.5"wheels
so I think there is no problem with the size
but what about the offset
the wheels that i wanna buy are +40
and here are some info. about the wheels
4 X Incubus Black Wheels
Suit almosy all 4 & 5 Stud Cars
Size 18 X 7.5 Inch
Chrome Nuts
Chrome Valves
Offset +40
PCDs Available 4/100, 4/114, 5 x100, 5 x 114, 5 x 120
Suit Cars Such as: Lancer, Corolla, Civic, CRX, Commodore, AU, BA and much more
4 x Brand New Kumho Tyres, size to suit your car.
so do they fit my car or no (without modification)
and if they do fit
what tire size do you recommend for the yaris
need some advice from you
waiting for your replies
regards,
Ashraf
ASHRAF is offline   Reply With Quote
Old 11-18-2006, 07:09 AM   #2
G'day
I'm using 18x7.5 on mine, with a 42mm offset. Tires are 215/35
I found there was a tiny bit of rubbing inside the wheel well at full lock, so you could do with a slightly wider stance.
Old 11-18-2006, 08:49 AM   #3
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Originally Posted by eTiMaGo
G'day
x2
I'am on 35 40 may rub if you drop it (i have a sedan with the TRD 18' ans ther is no rubbing
I Drive a 129whp Yaris ;)
Old 11-18-2006, 10:59 AM   #4
Actually I just realized something, when they put in the new front brakes it spaced out the front wheels a little, and there's no more full-lock rubbing
Old 11-18-2006, 11:10 AM   #5
the_saint
50% borikén
the_saint's Avatar
Drives: 06 Mazda5, 90 240sx
When they did your BBK? What exactly did they replace with the BBK?...unless the had to put a wheel spacer in so the wheels would clear the calipers...
'06+ Toyota bB
Garson - D.A.D. aero
Zuenglein Dolci wheels
the_saint is offline   Reply With Quote
Old 11-18-2006, 11:19 AM   #6
ASHRAF
Scubie Du
i'm not very experienced in the wheels issue
(so you could do with a slightly wider stance) what do u mean by stance?
so what do u recommend that i do?
Old 11-18-2006, 11:23 AM   #7
the_saint
50% borikén
the_saint's Avatar
I'm no good at explaining stuff, so check out this link instead.wheel tech
'06+ Toyota bB
Old 11-18-2006, 06:46 PM   #8
well from what i see there is no spacer, but the brake disc itself is probably a little thicker than stock, which makes it work like a spacer.
A wider stance would mean a lower offset, but I may be mistaken, always get confused by that
Old 11-18-2006, 06:51 PM   #9
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by ASHRAF
Hi every body
I would recommend 225-30-18, this size will keep the exact overall height as stock tires, plus a 225 width would fit very nicely on a 7.5 inch wide wheel, and 225's give a hugh handling upgrade
Old 11-18-2006, 07:33 PM   #10
ASHRAF
Scubie Du
thank u for your advice
is it ok to be +40?
see ya
Old 11-18-2006, 07:39 PM   #11
Black Yaris
der Zeck
I am running the stock +38 offset and I am running a 7 inch wide wheel and I am fine.... +40 will move the wheel inward 2 mm, which would look better on a 7.5in wide wheel... you should have no problems at all
Old 11-18-2006, 07:55 PM   #12
ASHRAF
Scubie Du
thank u black yaris for u r useful advice
and thank u guys also for trying to help me with the wheels
see ya
Old 11-19-2006, 10:26 AM   #13
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
I have 215/40/18 and the same problem that etimago had. It's rubbing a little in a full lock. I had 225 tires in the back and rub some times. Maybe is better 205/35/18 to avoid problems. Because of some roads here in Puerto RIco is why I'am using 215/40/18. About the offset, sorry I don't now mine.
Yaris_PR is offline   Reply With Quote
Old 11-19-2006, 11:49 AM   #14
Black Yaris
der Zeck
were you running a 225-30-18? because 215-40-18's are actually a taller tire than a 225-30-15.... I am running a 225-50-15 with no rubbing problems, wich is a hair taller than stock, where as 225-30-18 is the exact height as stock, long as you go with the propper offset +36 to +40 should be fine
Old 11-19-2006, 01:51 PM   #15
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
This may sound stupid but my wheel / tire combo is WAY over stock - Im running a +40 offset on the wheels and 225/30/20 tire. I have full-lock rub (Ill be posting some pics later) If your going to run 18's with +38 offset and use a 215 tire with 30-35 series rubber you should be good. I have small amounts of rub on large bumps but thats probably due to the 80lbs of stereo in the back and having the whole family in the car (stock suspension doesnt help either)
mikeukrainetz is offline   Reply With Quote
Old 11-19-2006, 10:25 PM   #16
Black Yaris
der Zeck
to be exact your tire is a full 2 inches taller than stock, I also did the measurements to see if I can run 20's, but in all reality, ya'll have never driven on Michigan or Ohio roads.... you ain't runnin a 225-30 tire with out fuckin up a wheel and/or a tire everyother week, and that is being carful... I did the 215-35-18 thing on another car and i finally said fuck it, I was tired of buying new wheels... moral of the story, if you want 20's on a yaris, move to a place with realy good roads (aka no snow salt damage)
Old 11-19-2006, 10:48 PM   #17
Yaris_PR
Yaris_PR's Avatar
Ok Black Yaris, using 18 rims, what size of tire it's going to be near stock size. Thanks for your help. Ohh by the way I really don't understand the offset thing
Old 11-19-2006, 10:53 PM   #18
Black Yaris
der Zeck
18's closest to stock would be a 225-30-18 on a 18X7.5 wheel with a +38 offset... off set determines how far in or out the hub mounts, in referance to the center of the wheel..... if the hub is dead center is is a 0 offset - offset set the hub deeper in the wheel and + more shallower.....
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
