#1 |
![]() Drives: 09 liftback yellow jolt Join Date: Jul 2009
Good brand solvents?
Hey, does anyone know of any solvents that are really good for removing annoying stuff like tar and grease off the side panels? I was thinking of using the 3m prep solvent 70 but it looks like that might take off the paint apparently.
Thanks for any responses! |
The Beautification of Car
Most of grease, tarm and glue i found Goo Gone work real good, but beside that i want to hear someone else opinions too about other products.
#3 |
![]() ![]() ![]() Drives: 08 Yaris Join Date: Oct 2008
just about any auto degreaser you can find will do the job.
and if i were you, depending on how concentrated the thing is, i would dillute it with water.
RIP Yaris, I will miss your superb handling a lot. darkmoon87's picture thread http://www.yarisworld.com/forums/showthread.php?t=10013 |
#4 |
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
I just use the cheap Turtle Bug & Tar Remover, works fine for me.
#5 |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
The strongest thing that I know of that won't hurt paint at all is Acrysol. It is made by Kent. It is WAY stronger than Goo-gone and Goof-off etc. Go-kart shops usually stock it.
#6 |
Thanks for the insight. I tried the goof off and it worked fine for most spots, but i still had to put in a lot of elbow grease for some areas. I think i might try the acrysol.
#7 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
denatured alcohol. strong stuff.
#8 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Dish washing liquid, straight or diluted works and it's environmentally friendly, no harsh or toxic chemicals. Be environmentally friendly!
#9 |
![]() Drives: 08 S 3DLB 068 Join Date: Apr 2009
#10 |
Rubbing alcohol will do the trick you can either use it straight or mixed with water. Just make sure you apply wax after you do this if not you're going to be riding around with no protection at all.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
| good deal? | Hershey | New YARIS Purchase Forum | 2 | 01-09-2010 09:38 PM |
| Good Books To Read? | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 23 | 12-15-2009 11:09 AM |
| BC coilovers: Good deal! | Trish | Items for Sale by private party | 19 | 11-12-2009 11:50 AM |
| Any one in Indianapolis know of a good job for a computer tech? | CtrlAltDefeat | Great Lakes | 15 | 10-28-2009 01:16 AM |
