#1 |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Apr 2009
Need new shoes. Will this rub?
After 3 potholes 2 of my rims are bent but still functional. I don't see the wheels and tires lasting for more than a month. I have been shopping around for wheels for my 2007 yaris sedan in polar white and I came across this tire at tirerack.com
sparco rally white painted 16x7 offset 37mm Backspacing: 5.51" Bolt Pattern: 4-100 Rec. Tire Size:205/50-16 Weight: 19.6lbs. I lowered the car with tein s tech which is about 2" drop and kept the stock shocks. I am planning on getting the tire size 205x45x16. Will this be ok or will it rub? I appreciate the help.
Drives: 07 sedan Join Date: Mar 2010
holy heavy wheels batman
#3 |
Drives: 2014 White VITZ Join Date: May 2007
With your set-up and those wheels, you'd be okay with a 195/50/16 tyre.
#4 |
I am ok with the 195 setup. Will 195/45/16 be ok? I don't really want to raise it up more and I found yokohama's for $100 at tire-easy.com.
