Old 04-02-2010, 06:54 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Key losing range
I'm starting to notice my key is starting to not open the doors on my 08 sedan until i'm standing right beside it,when i bought the car i could lock or unlock or activate the horn from several hundred feet,I'm assuming i need a new battery in the key and if so what kind of battery would i be needing.
Old 04-02-2010, 07:19 PM   #2
nemelek
DWEED
nemelek's Avatar
I have an after market system and can't say what your exact size would be. However ebay is a real cheap place to buy a replacement battery.
Old 04-02-2010, 07:37 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
just see how it comes apart, most likely a screw in the back, but I have never seen one.
there will be numbers on the top of the battery you can use to find a replacement. I got one for someone else and it was like 2 dollars no shipping on amazon
Old 04-02-2010, 09:26 PM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
lolz this may sound funny to you but it works..my battery is 3 years old got it since i got the car and use the car everyday..longer range try putting your remote under your chin. then press ofcourse...i tested it and its 90 % accurate that it gives you more range... try it no joke.
Old 04-03-2010, 12:41 AM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
just head over the radio shack... they have tons of different battery types, and they will probably open the thing up for you and install the battery right in front of you for free.
Old 04-03-2010, 02:50 AM   #6
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
this does work, i do it too
it sounds like its your battery- if its part of your keyfob just go to the toyota dealer
Old 04-03-2010, 06:05 AM   #7
jambo101
jambo101's Avatar
I saw that demonstrated on Top Gear,impressive
Old 04-05-2010, 01:35 AM   #8
Revsson
Check out page 17 & 18 of the 2007 owner's manual, as it shows how to
replace the battery. They state it is a CR2016 Lithium battery.
http://www.etimago.com/yaris/repairmanual/Owner's%20Manual.pdf
Marcus - where is the "ofcourse" button I need to press with my chin?
Old 04-05-2010, 02:53 AM   #9
YarisSedan
Drives: 08 Yaris Sedan
I do this sometimes when im trying to find my car in the parking lot it really amplifys the range. Something about turning your body into a human antenna booster.
Old 04-05-2010, 10:03 AM   #10
marcus
toyota
marcus's Avatar
yah im sure theres a downside somewhere down the road..then again same as standing in front of a microwave while waiting for your food..lolz
Add remote to factory keyless. imknotright DIY / Maintenance / Service 50 03-24-2018 12:10 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
Key doesn't work jambo101 General Yaris / Vitz Discussion 13 06-10-2009 06:59 PM
My cool fancy new switchblade key with remote =) YarisSedan Cosmetic Modifications (Exterior/Interior) 14 05-14-2009 02:22 PM
Yaris transponder key: do we ALL get one?? auxmike DIY / Maintenance / Service 10 12-01-2008 10:40 PM
