Old 04-03-2010, 12:39 PM   #1
Tracid6
Drives: 2009 3dr HB
Wheels 16`s
Hello,i need help with choosing the right size tires to fit on 16x7 with 40mm offset without any rubbing issue, on my wife 09' Yaris HB 3dr with stock suspension.I was thinking 205`s 55...thx for any help and info.
Tracid6 is offline   Reply With Quote
Old 04-03-2010, 01:01 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
205/50
Old 04-03-2010, 01:15 PM   #3
yep, 205/50 and it's possible you'll get rubbing with passengers or cargo, IF your car is lowered.
Old 04-03-2010, 02:09 PM   #4
Tracid6
Drives: 2009 3dr HB
It wont be lowered,i just wanna be sure to not have ANY rub,and was thinking about 55 profile to keep the speedometer as accurate as possible,since factory wheels where 185/60/15
Old 04-03-2010, 02:50 PM   #5
Billiam
With a 15 inch wheel a 205/55 would be spot on. However you'll need to stick with the 205/50 with a 16 inch wheel. The difference in rolling diameter between the stock 185/60/15 and a 205/50/16 is negligible.
Old 04-03-2010, 03:52 PM   #6
Tracid6
Drives: 2009 3dr HB
So best match on those wheels with stock height would be 205/50 without any problems?
Old 04-03-2010, 08:47 PM   #7
Billiam
185/60/15 = 23.7 inches - stock
205/50/16 = 24.1 inches - 1.4% too slow
205/55/16 = 24.9 inches - 4.8% too slow
As you can see the 205/50/16 is a good match for the stock rolling diameter. Anything within 3% is considered acceptable.
Old 04-04-2010, 03:01 AM   #8
Tracid6
Drives: 2009 3dr HB
Then as long as it wont rub,definitely 205/50 tires are the good match. Thanks
Old 04-04-2010, 01:54 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
I have several sets of 16x7's, all with 205/50's and have never had any rubbing.
205/50/16 is the recommended tyre size here in the States.
Old 04-04-2010, 02:08 PM   #10
kimona posted, you can close the thread now, because that is the final word! LOL
Old 04-04-2010, 03:23 PM   #11
Vang
Drives: 2008 Yaris Sedan
how is 205/45/16 tires with same specs as op? negligible difference i suppose from 205/50/16s?
Vang is offline   Reply With Quote
Old 04-04-2010, 06:44 PM   #12
Billiam
Unless you need it for clearance reasons (as in lowered).....it's a bit short IMO.
Old 04-04-2010, 09:17 PM   #13
Kal-El
Kal-El's Avatar
Yeah, I run 205/50/16's and that is a perfect setup. Although I'm on stock suspension so I still have a bit more gap than I'd like. But never any rubbing even at full turn.
Unless you're lowered, it won't look good at all. Too low and even more wheel gap than stock - which is a lot!
Old 04-04-2010, 09:29 PM   #14
Vang
well look likes i'll have to suffer the gap i'm going to get with that until i can afford some trd's or nf210s then
JDM Wheels and some track wheels/tires jdmekcivic Items for Sale by private party 10 09-08-2009 12:27 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
