Old 04-05-2010, 02:38 PM   #1
rossman
Drives: 2006 YARIS RS
Cool Rubber suggestion
I need to purchase some new tires for my rims.
Currently I have:
Yokohame AVS ES100 (205/45 R17) on OZ Superturismo rims
The tires had good traction but made too much noise and had uneven tread wear.
I do a lot of city and highway driving, I am looking from some rubber that will last and not make too much noise.
Any suggestions?
Thanks
rossman is offline   Reply With Quote
Old 04-05-2010, 04:07 PM   #2
severous01
i had fuzion zri's on my camaro...much more quiet than eagle gsc (crap tires), yoko's, and bridgestones.
cooper is a good tire, and i'm shocked you're having problems with yoko's. wear issues any way, do you have it lowered? did you check the alignment? if you're feathering it may be a shock/spring issue, not a tire issue.
Old 04-06-2010, 01:32 AM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Lower-profile tires will make noise, so you will have to get used to it. And like severous01 says, get that alignment done (FYI, the alignment guy may require you to get new tires before service if the worn sections are completely bald, for your own safety).
As for which tires: http://www.yarisworld.com/forums/sho...26&postcount=9 in 205/45/17
Old 04-06-2010, 07:01 AM   #4
AND189
Drives: 2
Bridgestone potenza adrenilins are the best try and wet low noise smooth ride very grippy
AND189 is offline   Reply With Quote
Old 04-06-2010, 09:13 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
Currently I have:
Any suggestions?
Thanks
Nice package!
Uneven tread wear is could be an alignment issue, balance issue, inflation issue or simply due to lack of regular tire rotation. Purchasing a non-unidirectional tire will allow more options come rotation time thus extending life. Otherwise you must flip and remount the tires on the rims to move them across to the opposite side of the car.
You can use the tire comparison tool at TireRack.com to see the rating of many fine tire choices. Noise level is one of several criteria indicated. NOTE: the US tire prices will either make you cry or very angry.
Simply select your tire size and search, then select the tires of interest and press compare. Include your current tire as a baseline.
Old 04-06-2010, 09:26 AM   #6
falken 912's are nice
FS: OEM Toyota Rubber Matts CB900F2 Items for Sale by private party 7 08-16-2009 07:35 PM
MY RUBBER BAND BALL! AGHHH!!! Sodium Duck Off-topic / Other Cars / Everything else Discussions 47 03-06-2009 01:56 AM
rubber protector sheets? enobmort42 Cosmetic Modifications (Exterior/Interior) 0 02-25-2009 10:41 AM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
Yaris Rubber Floormats? galaxyhillvt Cosmetic Modifications (Exterior/Interior) 18 11-26-2006 07:52 PM
