Old 04-15-2010, 11:31 PM   #1
wowitswil
wowitswil's Avatar
Drives: 2010 Yaris 5 Door
NEED HELP PLEASE!!!
finally got my afe intake today....after installing everything was fine up until i hit the highway and wot.....then CEL and TRACTION CONTROL LIGHT is on...2010 hatch......is there a solution?
silly yaris....octane 93 r for kids!!!
wowitswil is offline   Reply With Quote
Old 04-15-2010, 11:45 PM   #2
Tatsh
Drives: 2009 Toyota Yaris LE
Check MAF Sensor and make sure all vacuum lines are connected.
Currently Done: Apex'i N1 Evolution Axle-Back, Tanabe DF210, Drag DR-31 (Rally Bronze) Wrapped in BF Goodrich g-force Sports, held together with Red Works RS Lug Nuts.
Tatsh is offline   Reply With Quote
Old 04-15-2010, 11:55 PM   #3
wowitswil
wowitswil's Avatar
everything looks connected...but i used one of the stock hoses....so im not sure if thats the problem.
Old 04-16-2010, 05:51 PM   #4
wowitswil
wowitswil's Avatar
i just reset the ecu...the cel is off...imma go take it for a run tonight..hopefully that will solve the case i just tightened the clamps more
Old 04-16-2010, 06:49 PM   #5
1NZYaris1
1NZYaris1's Avatar
doublecheck where it connects to the Throttle body , and that the MAF sensor is seated properly.
as you could also have a air leak .
Old 04-16-2010, 09:08 PM   #6
wowitswil
wowitswil's Avatar
everything seems fine so far....but the test is later tonight =D
