Old 04-16-2010, 09:04 AM   #1
06_hbyaris
Drives: 2006 Yaris 5 Door HB
Power window doesn't work
Hi guys,
My 06 Yaris has an aftermarket power window motors/switch install by a local shop. It works fine until yesterday I tried to use the switch to roll down the window won't move. What do I need to check? Fuse? Switch connection?
Thanks
06_hbyaris is offline   Reply With Quote
Old 04-16-2010, 06:31 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by 06_hbyaris View Post
Hi guys,
Thanks
could be a fuse, or a solenoid/actuator... or maybe even a relay depending on the aftermarket kit... I'd take it back to the shop and ask them to check it out, explain that you bought it there. If you live in a different place... find a shop that appears to be slow (not many customers) and ask them... if they are slow they're more likely to fix it quickly, and if it turns out to be a quick fix (like a fuse), probably won't charge much.
Old 04-16-2010, 08:53 PM   #3
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
I totally agree ^^
Malifabian is offline   Reply With Quote
Old 04-16-2010, 09:02 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
When you activate the switch can you hear the motor engaging or there is no vibration from the door or sound?
From Manual Window/Lock to Power W/L eocintron Cosmetic Modifications (Exterior/Interior) 5 11-10-2009 10:31 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
