Old 04-17-2010, 02:12 PM   #1
Roth5150
Drives: Yaris 2003
Post Yaris Engine Shake
Hi,
The engine on my Yaris starts to shake when in idle and as I start to accelerate I can feel the engine sputtering. Any suggestions before I take it to the dealers.
thanks
Roth5150 is offline   Reply With Quote
Old 04-17-2010, 05:02 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Is the Check Engine light on? If so, you need to get the code. Is this car at a high enough mileage to need spark plugs?
Old 04-17-2010, 06:26 PM   #3
Roth5150
Drives: Yaris 2003
Thanks Yaris Hilton,
No check light on, car has roughly 60,000 miles on display, I don't have the service history so not sure when the spark plugs were last changed?
Old 04-17-2010, 08:04 PM   #4
06silveryaris
Drives: 2006 yaris
I think the spark plugs are supposed to be good for 100k but don't quote me. I feel like I read that somewhere.
06silveryaris is offline   Reply With Quote
Old 04-17-2010, 09:38 PM   #5
Yaris Hilton
At least the U.S. models have 100,000 mile iridium plugs.
Old 04-17-2010, 10:04 PM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If it's 2003, it might have platinum plugs and need to be replaced at 50,000 miles. It could also be clogged injectors.
Old 04-17-2010, 11:32 PM   #7
Yaris Hilton
Smile
Yeah, I think the plugs were platinum in those days. My daughter's 2001 Echo started acting that way as it was getting close to 100,000 miles with those 50,000 mile plugs in it. Changed the plugs, cleared the random misfiring code, and everything was fine.
Old 04-18-2010, 05:21 AM   #8
AND189
Drives: 2
mounts maybe ?>
AND189 is offline   Reply With Quote
Old 04-18-2010, 08:22 AM   #9
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
spark plugs or something's wrong with the electricity goin' to the engine ...
any mods which require much electricity u installed may affect the battery life and therefore u may need to check on the battery
BLOODY_STONE is offline   Reply With Quote
Old 04-18-2010, 09:01 AM   #10
Roth5150
Drives: Yaris 2003
Thanks everyone,
I will check the plugs and battery, How do you un-clogg the injectors?
Old 04-18-2010, 09:54 AM   #11
Originally Posted by Roth5150 View Post
Thanks everyone,
Run a bottle of injection cleaner through it from you local parts store.
Edit: you add it to your gas when you fill up.
Old 04-18-2010, 01:17 PM   #12
Roth5150
Drives: Yaris 2003
Cheers Bluevitz-rs I will try this
Old 04-18-2010, 02:23 PM   #13
Hershey
the '08 sedan idles rough when at redlight , etc.. When I put it in neutral it's less noticeable . Put TECHRON with a fill of 93 octane to no avail .
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 12:21 PM
Is the Yaris engine a little rough? thomasward00 General Yaris / Vitz Discussion 23 04-30-2007 12:17 PM
