Old 04-20-2010, 08:28 PM   #1
Chemware
Drives: Yaris YRS 5 dr 1.5
Tyres 185/60 R15 -> 195/55 R15 ?
A quick question: I need to replace my OEM tyres (185/60 R15 on 5.5Jx15 steel rims), but they are rare and expensive here in Australia ($140+ per corner).
195/55 R15s, a "performance" tyre is $10-$20 cheaper, so I am considering them. Some tyre shops recommend this, others say it's a bad idea.
Also, would I need new rims ?
Does anyone here have any experience ?
TIA,
Mat
Chemware is offline   Reply With Quote
Old 04-20-2010, 08:50 PM   #2
bankrobber
Drives: 2007 Yaris Hatchback
I would ask to try them out for a hundred miles.
Old 04-20-2010, 09:43 PM   #3
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
Just order from tire rack (not sure what shipping would be), the 185/60 15 are like $50 or so each. Store brand ones are like $35.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 04-20-2010, 09:57 PM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
195/55-15 is a good fit for the Yaris. A touch wide for the stock 5.5" wide wheel, but not enough to be problematic. Most 195's are spec'ed for 5.5-7.0" wheels.
Old 04-20-2010, 10:37 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
195/55/15 is a good fitment for the Yaris. Recommended wheel width for a 195mm tyre is 5.0-7.0, so no worries whatsoever.
However, 205/55/15 is a better replacement size for the 185/60/15. Recommended wheel width for a 205mm tyre is 5.5-7.5, so a bit tight but a very safe fitment. Many Yaris owners with stock suspension (or a mild drop) run 205/55/15's.
Old 04-20-2010, 10:49 PM   #6
Chemware
Thanks guys!
Looks like the 195/55s are OK, but check the brand for 5.5Jx15 compatibility.
Tyre Rack has 23 tyres, most in the US$60-70 range (AU$70-80). Far cheaper than here. But looks like they ship to US and Canada only :(
