Old 04-26-2010, 08:13 PM   #1
tonysantos89
Drives: 2008 yaris
Question help plz! for grounding for an amp 2007 yaris
i think i have a bad ground for my amp. i am still using the stock head unit so i was thinking that this might be a problem too.. where do everyone else ground their amps to in the trunk? thanks
tonysantos89 is offline   Reply With Quote
Old 04-26-2010, 08:23 PM   #2
i unbolted the rear folding seat, and bolted the ground there....
made sure to scratch off all the paint in that area...
Old 04-26-2010, 10:33 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I will have to check in the a.m.. I cannot recall where my amps are grounded, I just know they are grounded in the trunk...
Old 04-27-2010, 10:06 AM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Here...
CLA 250, 4MATIC
Old 04-27-2010, 10:08 AM   #5
centrysis
centrysis's Avatar
Drives: '08 Yaris LB
Mine are actually under the front seats, but are also grounded to the seat bolts. No problems.
centrysis is offline   Reply With Quote
Old 04-27-2010, 10:21 AM   #6
bitz767
Drives: 2010 Black Manual 3 door
ditto on the seat bolts
bitz767 is offline   Reply With Quote
Old 04-27-2010, 10:27 AM   #7
fnkngrv
fnkngrv's Avatar
Here...
That is where I have mine as well...
Old 04-28-2010, 12:00 AM   #8
goku87
goku87's Avatar
Drives: Black HB
Not hijacking.
Here...
How noticeable of a difference did that sound deadening do for you?
Old 04-28-2010, 01:19 AM   #9
derickveliz2
I'm using a different technique that what we are used to see, what you see there are CLD Tiles and they only need to cover 25 % of flat panels, 1/4" CCF on top and a full layer of MLV does the trick.
To answer your question, the difference is like day and night, this is the thread...
Yaris Sedan Deadening and Sound system upgrade
Thanks
D.
CLA 250, 4MATIC
Old 04-28-2010, 01:25 AM   #10
derickveliz2
Check out this video, it shows how the CLD Tiles work to control resonance
VIDEO
D.
CLA 250, 4MATIC
