Old 04-26-2010, 11:13 PM   #1
eddy
love to drive
Drives: 2010 yaris sedan
fuel filter
Are the fuel filters on these wonderful little cars in the gas tank?
eddy is offline   Reply With Quote
Old 04-26-2010, 11:27 PM   #2
detroiter
detroiter's Avatar
That's what I've heard but not sure if it's true
Old 04-26-2010, 11:45 PM   #3
bronsin
bronsin's Avatar
On an ECHO yes they are. They are integrated with the fuel pump. Theres no requirement they be replaced either. I would think the same is true for the Yaris.
Old 04-27-2010, 12:53 AM   #4
yariphilia
Drives: 08 lb
it is true for the yaris, hopefully no1 has to worry about theirs.
yariphilia is offline   Reply With Quote
Old 04-27-2010, 10:30 AM   #5
Hard_Yaris
Drives: 07 Yaris
I think I had one go on my 2005 echo with 200,000km...
Basically i had to fill the gas tank up on the slowest setting at the pump.
Not sure if it was the filter or something else. anyway it was impossible to fill the tank.
Hard_Yaris is offline   Reply With Quote
Old 04-27-2010, 11:22 AM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
That's a clogged tank vent hose, not the fuel filter.
Old 04-27-2010, 01:30 PM   #7
Hard_Yaris
Drives: 07 Yaris
Thanks Yaris Hilton...
how does the vent hose get clogged?
Old 04-27-2010, 01:35 PM   #8
Yaris Hilton
Smile
A kinked hose, debris in the tank, deteriorating rubber inside the hose blocking the lumen... I recently had to replace the fuel hoses on a Diesel engine that had rotted and blocked themselves. My problems with vent hoses have been with cracking and leaking rather than plugging. I suppose you could have something in the filler pipe as well.
Old 04-27-2010, 01:50 PM   #9
Hard_Yaris
Drives: 07 Yaris
ahhh.... I understand now!
Old 12-17-2010, 09:10 AM   #10
anahtar
Drives: 07 Yaris
You don't have to change the fuel filter on a YARIS?
anahtar is offline   Reply With Quote
Old 12-17-2010, 10:10 AM   #11
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
nopers.. i think its more of a strainer attatched under the fuel pump inside the tank. but no filter from the pump to the injectors
Old 12-17-2010, 05:49 PM   #12
Happy Little Pony
Drives: 2007 Yaris HB
Most of the gunk in a gas tank is actually rust and corrosion from the tank itself. The Yaris has a plastic gas tank. No metal means no rust. Any fuel you put in should be getting filtered at the pump.
I personally like the idea of having a user changeable gas filter, but I've never actually needed to change one because it was clogged. Toyota obviously feels that the small amount of foreign matter introduced into the tank can be handled by the built in filter for the life of the car. Unless something goes dramatically wrong, they're probably right.
Happy Little Pony is offline   Reply With Quote
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
