Old 04-27-2010, 06:10 AM   #1
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
oil viscosity in 2009 yaris
hello,
I have a 2009 5dr multimode hatchback yaris.
In Israel the weather is hot in the summer and the temperatures aren't hot during the spring and winter.
when i bought my yaris,the service interval is 15,000 KM or 1 year. as stated by the dealership.
the oil viscosity the dealership put in is 10w-30 and it's semi-synthetic.
the car has made 6100 km since august 2009 (i don't drive much since i have a car from work sometimes).
i want to preserve the engine in top shape.i was recommended to put synthetic oil and i chose the ROYAL PURPLE brand (we don't have amsoil,shell,castrol in here since the companies don't import them).
has anyone here who's using RP synthetic oil and can recommend a different viscosity?the manual says 5w-30 and NOT the 10w-30.can someone recommend the proper viscosity due to the climate?
can i shortage the service intervals?
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 04-27-2010, 08:24 AM   #2
In hotter weather it is ok to use 10W30. The oil just remains a little thinker when cold. And service interval has more to do with how you drive your car than a set number.
If all you do is short trips I'd recommend 6000-8000km with full synthetic and slightly less with regular oil. If most of your driving is long trips then you can stretch it out longer to the recommended service interval. Don't worry about the oil being more than a year old though if you don't drive that much.
Old 04-27-2010, 09:19 AM   #3
matanfr
matanfr's Avatar
my manual says 0w-20 is recommended and if there is 5w-30 you can use it but it needs to be replaced at the next oil change.and about royal purple?has anyone operated with it in hot climate?
Heretics of dune.
Old 04-27-2010, 11:17 AM   #4
TheSilkySmooth
TheSilkySmooth's Avatar
Can you get Motul 8100 X-Max LL01 5w-30? or Total(ELF) QuartZ Platinum 0w-30? These are real synthetic oils. IDK where the idea that RP is a top syn comes from. AFAIK it semi syn - in U.S. oils do not have to be true synthetic to say "Full Synthetic' on the product label. Insanity!
Old 04-27-2010, 11:24 AM   #5
PH3N1X
Drives: 2008 Red Yaris 4 Door
LOL @ using high performance Synthetic oil in a low load, low power 1.5l 4 Cylinder!!
PH3N1X is offline   Reply With Quote
Old 04-27-2010, 11:44 AM   #6
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Its not a matter of horsepower its a matter of fuel economy.
Old 04-27-2010, 03:07 PM   #7
matanfr
matanfr's Avatar
in Israel we don't have 1.5L.we have 1.3L 100HP.it's not the same configration as in the US.
Heretics of dune.
Old 04-27-2010, 03:08 PM   #8
matanfr
matanfr's Avatar
no we can't..these companies don't export to israel.
we have royal purple (if you ask the importer of these),mobil1 and AGIP.
Heretics of dune.
Old 04-27-2010, 03:33 PM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
That explains your manual's recommendation of 0W-20 oil. In the U.S. Toyota still recommends 5W-30 for the 1500cc 1NZ-FE engine, though a service bulletin says 5W-20 may be used.
Old 04-27-2010, 03:36 PM   #10
And I think in Canada it's 0W-20 or 5W-20 on the 710 cap.
Old 04-28-2010, 11:49 AM   #11
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I just googled prices on the Motul and Total brand oils.... 5L jugs go for like $45 on the internet (plus shipping)... or $10 a quart. Unless I could get away with 20K mile intervals it'd be cheaper to just continue doing my 10K intervals with Mobile1 for $26. I'm sure those oils would be fine for around 15k... but 20... errr... i dunno.
Old 05-17-2010, 12:35 PM   #12
TheSilkySmooth
The perceived performance difference can be great. M1 0w-30 is not a long life oil. look for ACEA A5/B5-04 or -08 for long drain capable mid HTHS oils. M1 5w-30 is semi synthetic and over priced compared to some of Mobils other oils (like the TDT or the HM 10w-30)
Old 05-17-2010, 12:40 PM   #13
TheSilkySmooth
Uh, that 1.5 is not "low load/ low power engine". Its 70hp/L, If it was a ford 4.6 modular it would make 320+ HP. is that low output? NO.
Old 05-17-2010, 02:32 PM   #14
Yaris Hilton
Smile
I'm rather amazed at that. Back in the '60s and '70s, only high strung race engines put out that sort of power, and this one will also happily grunt uphill at 1400 RPM. And then along come young whippersnappers berating the Yaris for having no power!
Old 05-17-2010, 03:22 PM   #15
My '92 Honda CBR 250RR makes 45hp stock @ 16500rpm. That's 180hp/L. But it only makes a lowly 18lb/f torque 12000rpm.
Old 05-17-2010, 03:36 PM   #16
Yaris Hilton
Smile
Yep. Motorcycles have put out some astounding specific power figures for a long time, by buzzing up to really high RPM by automotive standards.
Old 05-17-2010, 05:45 PM   #17
bronsin
bronsin's Avatar
I LOVE motorcycles! Cars are so boring. Even the "hot" ones.
Old 05-17-2010, 06:24 PM   #18
I love both, that's why I have one of each.
BTW, 5W-20 FTW
Yaris Sedan 2009 question t0m4s Cosmetic Modifications (Exterior/Interior) 3 06-25-2009 10:54 AM
How much did you pay for 2009 Yaris hatchback MT? Mischa New YARIS Purchase Forum 9 05-21-2009 11:35 AM
