Old 04-27-2010, 09:39 AM   #1
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
Sway Bar.
I am a total Noob to suspension mods. Can someone tell me how much and what difference would a sway bar make to my Yaris?
Thanks!
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 04-27-2010, 09:59 AM   #2
minnyar
Drives: 2007 Yaris Sedan (5pd)
Looks like you are bone stock from a suspension setup. As was I two weeks ago, then I installed the UR 23mm sway bar. You absolutely can feel the difference. Turn in, much sharper, increased stability all around, and less body roll. Where before I had to brake and downshift to 2nd to make a 90 degree turn, I can leave the car in 3rd. Put it this way, I will need new tires soon, because corners are way to fun now!
minnyar is offline   Reply With Quote
Old 04-27-2010, 11:45 AM   #3
Falconeer
Bayou Blue Pearl.
Interesting... is this felt at all speeds?
Old 04-27-2010, 11:51 AM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Adding or enlarging a rear swaybar provides less body roll, less understeer, sharper steering response and greater stability at speed.
You won't feel it much when you're going straight except for greater resistance to cross-winds and that sort of thing. You will feel it in any turn at any speed.
Old 04-27-2010, 12:00 PM   #5
minnyar
I think what you notice all around is the increased stearing response. At highway speeds, as Loren mentioned, the car seems stiffer and wallows less. Driving in a straight line at 30mph you will not notice the sway bar, but that's boring:)
Old 04-27-2010, 12:24 PM   #6
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thanks!
It would make your face go from to on each turn!
Then you are going to start saving gas on turns. (no need to slow down)
CLA 250, 4MATIC
Old 04-28-2010, 07:12 AM   #7
Falconeer
Bayou Blue Pearl.
I'm getting one. :D
Old 04-28-2010, 09:48 AM   #8
derickveliz2
I'm getting one. :D
You are going to LOVE it!
CLA 250, 4MATIC
Old 04-28-2010, 11:17 AM   #9
arunto
arunto's Avatar
Drives: 2008 Yaris LB
i used a UR 23mm on totally stock suspension and wheel setup this past winter and it was great. it lessened the body roll and was still very predictable at the upper limits.
arunto is offline   Reply With Quote
Old 04-28-2010, 12:19 PM   #10
Mister Z
Drives: 08 Yaris HB
So whats the difference in running a 19mm vs. a 23mm rear sway bar? I currently have tein S-techs on my yaris and was wondering which sway bar would be better. I've been told that the 23mm will give me more oversteer with my current set up. is that true?
Mister Z is offline   Reply With Quote
Old 04-28-2010, 12:22 PM   #11
Loren
What?
Loren's Avatar
Less understeer. Less body roll. Everything a swaybar does, a larger swaybar will do more.
The 23mm bar isn't enough to "cause" oversteer in a Yaris, though. It's still a FWD car.
Old 04-28-2010, 01:51 PM   #12
yarr_is
Drives: yaris
swaybar is the best cheapest mod you can do on a car...
Partially Sponsored by:
Tanabe USA
yarr_is is offline   Reply With Quote
Old 04-28-2010, 02:14 PM   #13
ddongbap
Balls out with a throttle lift off could change that though.
Old 04-28-2010, 02:16 PM   #14
Loren
What?
Loren's Avatar
We'll assume the OP doesn't drive like a complete moron on the street.
(that kind of maneuver done just the wrong way could have a completely stock Yaris in an oversteer condition)
Old 05-03-2010, 12:44 PM   #15
MUSKOKA800
MUSKOKA800's Avatar
Thanks!
A HUGE improvement with no downside. Do it!
Old 05-04-2010, 06:04 AM   #16
ddongbap
Mmm.. oversteer. First time offenders will probably end up tightening their sphincter. You know which one I mean.
Old 05-04-2010, 08:42 AM   #17
Falconeer
Bayou Blue Pearl.
has anyone tried this:
GTSPEC Rear Sway Link Brace Toyota Yaris 07+http://www.vividracing.com/catalog/g...7-p-47147.html
What do you think?
Old 05-04-2010, 10:33 AM   #18
Loren
What?
Loren's Avatar
What do you think?
Not a swaybar. Impossible for it to have the effect of a swaybar with those bushings on the center section.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
