Old 04-27-2010, 04:09 PM   #1
colinr5779
Colin Richardson
Drives: Yaris Sr 1.8 Dual VVT-i
Oil light
Turns on and off on sharpe turns and roundabouts ! any1 else have this problem ?
colinr5779 is offline   Reply With Quote
Old 04-27-2010, 04:59 PM   #2
nemelek
DWEED
nemelek's Avatar
No I don't. I would check your oil level and add more to put it on the full mark.
Old 04-27-2010, 06:23 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
simple solution... STOP TURNING... geez.
Old 04-27-2010, 06:30 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
are you sure its the oil light?
Mine does this when my windshield washer fluid is low
Old 04-27-2010, 07:00 PM   #5
dingbat
Drives: '10 3D Liftback
+1, Do it now!
dingbat is offline   Reply With Quote
Old 04-28-2010, 11:25 AM   #6
colinr5779
Colin Richardson
Topped it up 2day with 1ltr its hard to gettin a clear reading
Old 04-28-2010, 09:27 PM   #7
dingbat
Was it low to start with?
Hard to get a clear reading on the dip-stick? Let the car sit for a while. Pull the stick and wipe it clean. Stick it in, pull it out again. Should give you an accurate reading. If you've just poured in cool oil, it can sometimes take a bit for it to work its way down into the pan. Best to let it sit and re-check to make sure you didn't over fill it.
Did adding oil take care of your light issue?
Old 04-30-2010, 12:31 PM   #8
colinr5779
Colin Richardson
i added 2ltr.. and it has took care of the light issue.. but im scared ive damaged the engine although everything seems ok part from a noise from my exhaust i think wen i start up :S getin tht looked at on wednesday. the reading is fine on the dipstick now and doesnt looked like ive filled it up 2 much
Old 04-30-2010, 01:06 PM   #9
It was down two full liters? That's a lot. You should check carefully for a leak.
Old 04-30-2010, 07:34 PM   #10
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yep. So far, mine doesn't drop the level discernably over a 5000 mile oil change interval.
Old 04-30-2010, 09:13 PM   #11
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Maybe you might check this thread out....
Oil light coming on and off
Stove is offline   Reply With Quote
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
