Old 05-03-2010, 07:56 PM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Goodyear Gatorback (Acc. belt)
Hey all,
This may be just my experience with this belt but, STAY AWAY. This belt squeals like a mofo on start because the material is slippery and/or it does not work well for our car (yes, I did get the proper part).
Had my mechanic re-tighten and it STILL does it. Not very healthy at all. Went back to an OEM belt and now things are fine.
If anyone has had any other experiences with the gatorback let me know what it has done to your car.
devinlamothe is offline   Reply With Quote
Old 05-03-2010, 10:57 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Only 2 belts id ever use is Bando first and if for some reason i cant get it then gates as a secondary. Both are OE belt manufactures for nearly all cars.
Old 05-04-2010, 10:51 AM   #3
1stToyota
1stToyota's Avatar
If at all possible, I use Bando or ContiTech first (Napa's Import Altrom line)...and their Gates belt if they're not available.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-04-2010, 11:38 AM   #4
I have always had good luck with Gatorbacks. I don't currently have any on either Yaris, but my Xterra is running two (main drive belt and supercharger belt) and my Bunton commercial mower is running a full set (four belts).
Old 05-04-2010, 01:21 PM   #5
severous01
i had a gatorback on my camaro...400+ hp, ac, 160 amp alternator...never had a problem. my jeep had one on it, put on at 60k miles and it was still good 6 yrs later at 275k miles.
buddy of mine said his was like 9 yrs old on his camaro. he said he's had to change just about every idler and tension pully 4-5 times but kept the belt.
i like the gatorbacks. they do hum a little bit but it's worthi it's weight in gold for what it does and how long it'll last.
Old 05-04-2010, 02:34 PM   #6
Rick
Drives: '08 Yaris LB 5M
I've got to give Gatorbacks their due also. I've got a ten year old Gatorback on my blown Cobra (~50K mi) that sees severe service regularly. At max boost the blower sucks about 75 horsepower more through the accessory drive serpentine belt than an OEM system would. I expected that belt to be an ongoing problem ... but it has not been.
For all I know it may not run quietly, but it's not louder than the blower.
Rick is offline   Reply With Quote
Old 05-04-2010, 08:08 PM   #7
devinlamothe
I just meant it's not good for the Yaris, lol. On start it ALWAYS slips and squeals like mad. Either that or my mech didn't do a good job tightening it.
I don't doubt on other cars it works great as I went by all the rave reviews on how quiet it is.
Old 05-04-2010, 09:14 PM   #8
If he didn't tighten it properly to begin with, the belt may have glazed. Once it's glazed, it'll squeal like a pig.
Old 05-04-2010, 10:43 PM   #9
devinlamothe
That could very well be. I hope this won't damage anything - I have an appointment set up for next Tuesday (earliest time I could get in ).
It freakin' squeals like crazy right in the morning and only for a few seconds every start after that. I just don't want it to snap.
Old 05-04-2010, 10:47 PM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
I just put a gatorback on my 1AZ-FE in the RAV with no problems..... I have always used gatorbacks, they last forever and have never squealed for me
Old 05-04-2010, 11:47 PM   #11
It won't hurt anything, except your ears. As long as the squeak stops once it's up and running then the alternator and waterpump are being driven.
Old 05-05-2010, 01:46 PM   #12
severous01
re-tighten and hit it with some brake cleaner while it's running. on the inside, not outside. also, dont use carb/choke cleaner as it leaves residue. and dont drench it, just tap the nozzle till the whole thing is wet.
Old 05-05-2010, 03:45 PM   #13
MUSKOKA800
MUSKOKA800's Avatar
Or try belt dressing. The product engineered for the purpose.
Industrial supply houses should have it if local auto parts stores don't.
Old 05-05-2010, 11:45 PM   #14
yarrr
Drives: 07 sedan
^^ but increasing friction by corroding your belt and taking half its life is so much more fun! Kinda like cutting extra grooves in your tires to keep them from spinning on a launch.
Old 02-27-2013, 12:22 PM   #15
reiving old thread...
I didn't research before buying, but i got the gatorback for my Yaris.. installed, drove 200km and let it sit outside.. it squeaked, then i re-tighten it and it never squeaked again.
Old 02-27-2013, 01:17 PM   #16
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
I put a $2.73 gates from rockauto, and it does chirp on start up, but thats it.
UberSilver is offline   Reply With Quote
Old 02-28-2013, 10:54 PM   #17
alanwagen
IMHO, I like Gates belts. Around $15 bucks.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-27-2022 12:37 AM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 10:58 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 10:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-13-2009 12:05 AM
