#1 |
Secret Agent
Drives: 2008 Yaris Hatch Join Date: Feb 2009
New Type-R shallow sub ( ouch! )
I was excited about these, until I seen the price.
I'm sure once SonicElectronix gets some, they won't be this expensive. But still....... OUCH! ![]() http://tinyurl.com/27cop3n
www.sonicelectronix.com for all your mobile audio needs! |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
We don't have them in stock yet but they are in our system. $299 for 10" and $349 for 12". I'm sure Sonic will be less than that.
#3 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
betcha they would go nice with a PDX amp...I love my Bazooka, but I might have to give this one a thought. You could nestle it right into the nook behind one of the rear wheels I am betting...
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#4 |
#5 |
Secret Agent
For $350.... you can just buy the KING of all shallow subs:
http://www.sonicelectronix.com/item_...o+13TW5-3.html
#6 |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
alpine 10 vs jl 13
To me they look almost identical spec wise, same power handling, and for one being 3 inches larger in diameter, the sensitivity is way to close to justify paying the more expensive cost.
#7 |
Audio Junky
For 1/10 the price Parts Express sells a low profile BOSS sub... Not that i'm recommending it, but... I am tempted to open up my box modeling software and see how the cheap sub actually would perform. Usually any sub $50 sub will work decently in a sealed box... and low profile subs usually have a low QTS which is good for small boxes... it might not be a horrible sub for a cheap & small setup.
I wonder if they have a BL curve for that New alpine like they did with the other alpine sub.... an SQ low profile sub would be awesome. |
#8 |
Audio Junky
is the sensitivity rated the same way? 1w/1m? cause 2.83v/1m will give different amounts of power depending on ohm load.... ie 4ohm will have half the power as a 2ohm load even when both are given 2.83v... Common trick used in audio to inflate sensitivity ratings by about 3dB.
#9 |
Secret Agent
The problem with MOST shallow subs is they don't move enough air, and they are not LOUD enough.
They all have great SQ in a small sealed box, but they don't hit hard. Most shallow subs have a short stroke. A 10" sub is small to start with, so a 10" sub with a short stroke just doesn't move enough air for a nice hit. ( which is why that awesome JL shallow sub is a 13" ) The new shallow Type-R subs are supposed to have a long stroke, and fast response time with the right power pushing them. As a result, they should provide great SQ with a hard hit in a sealed box. They are also EXPENSIVE. The only reason my standard 10" Type-R is loud enough, is because it has a fairly long stroke ( 18mm Xmax ) and it is in a large ported box. ( and I am giving it enough power to push it ) I would prefer to run TWO 10" subs in a sealed box, but that would require a larger amplifier, and I would lose ALL my hatch space. My current setup cost me HALF my hatch space, and I am not really happy about that either, but it's the price I pay to have "some" bass in my music. Gotta do what ya gotta do.
#10 | |
#11 | |
Audio Junky
There are even tricks to smoothing out frequency response graphs which make it look like subs play better than what they actually do. |
#12 |
Secret Agent
You are correct. Data can be manipulated.
Speaker sensitivity is supposed to be 1w at 1-meter with a 1k test signal. And of course, that would be okay if you were testing midrange speakers. A sub does not operate at 1khz. Usually, the sub LPF is set around 100hz. ( Well below 1k. ) Bottom line is: we look at the product. We look at the specs. We read user reviews. We look for a good deal. We buy it and hope we like it. Sometimes we do, sometimes we return it and try a different one. It's all a game. Fun to play. Even more fun when we WIN!
#13 | |
Audio Junky
Tone generators are fun things to play with. |
| Any diabetics on Yaris World? | jjonrofl | Off-topic / Other Cars / Everything else Discussions | 36 | 04-08-2010 10:42 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Engine Type | lily | General Yaris / Vitz Discussion | 34 | 10-09-2009 01:23 PM |
| TYPE X | ChinoCharles | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 09-17-2007 03:21 PM |
| **CUSCO Type OS strut bars** | C2AUTOSPL | Sponsors Classifieds Area | 12 | 08-04-2006 10:35 AM |
