Old 05-05-2010, 11:48 AM   #1
cdydjded
Drives: Yaris LB Turbo
FACTORY INJECTOR SIZE
Just flowed the factory 1NZFE injectors on a flowbench. Results were 200cc. Next I am going to flow the 1ZZ injectors.
cdydjded is offline   Reply With Quote
Old 05-05-2010, 12:17 PM   #2
127.0.0.1
200cc what ? makes no sense
what reference ?
what fluid did you use, heptane ? 50/50 ? alcohol ? Viscor calibration fluid ?
what voltage, ohms, current, what duration ?
what filter did you use ?
all the above changes everything when testing injectors
Old 05-05-2010, 01:32 PM   #3
cdydjded
Sorry I dont have all the info you are asking about. If it helps it was flowed on a Lucas Fuel Injector Testing machine. The 200cc result is from taking the 25cc of fluid it flowed into the container and multiplying times 8, 25x8=200cc. He did remove the filter from the injector. If this is an incorrect way of flowing injectors, then the guy that did it is a fool.
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Want to connect a sub/amp to your factory HU? Navone N-85V Variable LineOut Convertor rningonfumes Items for Sale by private party 0 03-18-2010 10:39 PM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 09:41 PM
looking for factory 15's or factory tires tealio Southwest 7 04-15-2007 01:51 PM
