Old 11-25-2006, 01:40 AM   #1
W.A.S.P
I love my Yaris!
W.A.S.P's Avatar
Drives: White Yaris Liftback 2 Dr. AT
Liftback Rear speaker installation tutorial (Pics)
Well, I decided to upgrade my rear speakers since I got a couple of Sony for the front and needed to match the power but add a little more bass.
First, look at the tabs' diagram so you will know what you will encounter when pulling the panel away from the car's body. You don' need to remove the rear seat or the weatherproof trim to pull the panel apart, just use patience, common sense and have a beer next to you and the process will be painless.
Keep this in mind, in the middle of the panel there is a pressure tab blue in color that is not pictured in the diagram; be careful not to break it. Place one hand on the inside of the panel to feel the tabs that you can't see; don't just yank the panel off. Once the panel is off you will see that there is a lot of room for even a sub woofer in that space, you can use several sizes of speakers on the stock location, as long as you have the appropriate brackets, you might have to drill new holes for some applications. I used the brackets provided with my Alpine speakers and had to drill three new holes for the new brackets. Since the stock speakers have a special connector you might have to cut the wires. No biggie; once you see what the stock speakers are made of you will know you'll not use them again!
Do this process in reverse to reinstall the panel and there you go! Enjoy the new sound!!!!
W.A.S.P is offline   Reply With Quote
How to remove rear speaker panel on a Liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 7 11-25-2006 01:45 AM
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
