Old 05-06-2010, 02:00 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
fnkngrv's Amp and Tube Install
Well after running the rear end of my audio system in a temp solution for a couple years I finally decided to finish things off. I didn't perform a DIY per se as I still only have my Blackberry as a camera, but I do have before and after pictures.
> I started off with the amp install by taking a slide bar from the hardware store and mounted it to the inside of the sidewall of my trunk.
> I then used cardboard to come up with a fitment template for my mounting board.
> I rerouted all my wiring to behind the new mounting board.
> I then mounted my board to the mounting bracket after wrapping the board in carpet that I could find as close to the other color in the trunk.
> I put the mounting board in place and screwed it down with one screw above the amp and one that sits under the amp.
> I attached the amp to the mounting board and reconnected the wires.
> Lastly I removed the cloth straps for my Bazooka Tube and installed the stainless brackets.
Before:
After:
Help with choosing Amp kit myt In Car Entertainment + Electronics (audio / video / alarm) 7 01-20-2009 02:00 AM
