Old 05-10-2010, 02:48 AM   #1
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
How to clean AFE filter?
My filter looks pretty dirty to me, what do you guys think? I've had it for about 10k miles. Does it look like it needs to be cleaned?
How exactly do I clean it? Is this the oiled or non-oiled version?
yarisitis is offline   Reply With Quote
Old 05-10-2010, 03:02 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
First take a strong vacuum and suck out the dirt from the outside. Then you can try one of those filter cleaning products. Pep boys sells one for their generic dry filters. You spray it on the outside and let it soak for about 10 minutes. Then gently run water in from the inside pushing the dirt out. Then let it fully dry before installing. Just be careful not to use really hot water as it may cause the material to shrink a bit.
Old 05-10-2010, 03:10 AM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
the instructions for the dry filter says to tap it and its pretty much cleaned then wash it for full clean.
Check out my Build thread:
Old 05-10-2010, 07:06 AM   #4
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
to be safe just use high pressure air to blow it clean, but like yaris sedan said blow it from inside out
nazier is offline   Reply With Quote
Old 05-10-2010, 10:07 AM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup,
Like he said...I have had my AFE since 08 and that is how I have cleaned mine. I clean mine out via air hose once a month since it is a 2 minute fix.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
AFE drop in filter Walter Performance Modifications 35 07-27-2010 08:24 PM
FS: AFE drop-in filter and Stock Airbox with Cutouts FunctionSpec Items for Sale by private party 16 06-02-2010 02:36 PM
Garm's AFE intake vs. TRD high flow air filter???? computerlove87 Performance Modifications 28 07-22-2009 06:05 PM
FS: AFE Drop-In filter in modified airbox mikenacarato Items for Sale by private party 6 02-09-2009 05:44 PM
