Old 05-10-2010, 07:52 PM   #1
hexengon
Drives: yaris
how do i remove my hubcaps
i am a car noob pls help me
how do i remove hubcaps from my '10 yaris
thanks
hexengon is offline   Reply With Quote
Old 05-10-2010, 07:56 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
Grab them and give them a good yank.
Old 05-10-2010, 10:09 PM   #3
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Yes, and read your owners manual.
Stove is offline   Reply With Quote
Old 05-10-2010, 10:22 PM   #4
Ryu
Use something to pry it open from the side or you probably can pull them out just using your hand from the side.
Old 05-12-2010, 06:05 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Why do you want to remove the hub caps?
Old 05-12-2010, 07:04 AM   #6
ddongbap
To get to the sweet chocolate center.
Or to get to the lug nuts.
Old 05-14-2010, 04:27 AM   #7
bankrobber
Drives: 2007 Yaris Hatchback
A thin screwdriver and work it around the wheel. Also if you have trouble getting them back on mix up some soapy water like dish soap and a gallon of water and pour it around wheel. Hub caps will go on much easier
Old 05-14-2010, 11:05 AM   #8
Lucas13
Drives: 07 Yaris LB
Just grab them and pull out, make sure that your butt doesn't end on the floor like happened to me once!!!
Lucas13 is offline   Reply With Quote
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Steelies or Hubcaps or ??? CtrlAltDefeat Cosmetic Modifications (Exterior/Interior) 50 10-24-2013 09:50 PM
[DIY] To remove logotipos of the mark Sérgio Barros DIY / Maintenance / Service 6 02-23-2007 07:32 PM
