Old 05-10-2010, 09:23 PM   #1
adigilani
adigilani's Avatar
Drives: Toyota Yaris Terra
Question fuel consumption calculations jumping up and down...
Hi everyone.
I have a Toyota Yaris Terra
The fuel consumption calculation on the small display where the clock is ticking displays funny values.
Sometimes it displays 4.6L/100KM and then suddenly 9.2L/100KM.
The actual MPG are not effected. Just the readings are jumping up and down very quickly.
Any help with understanding what is happening and what is the cure.
adigilani is offline   Reply With Quote
Old 05-10-2010, 09:29 PM   #2
yarrr
Drives: 07 sedan
We don't have digital displays or mileage displays in the US, but what you're probably seeing is called instantaneous mpg. At any given second your fuel consumption can be very different. High rpms and wide open throttle takes a lot more gas per mile than cruising in neutral - if your car has DFCO, like the US yaris, you would see it jump to 0L/100KM or 999 mpg, because the car is moving and using 0 fuel.
Old 05-10-2010, 09:33 PM   #3
adigilani
adigilani's Avatar
thanks for your quick response yarrr. I am not very technical with the cars. So you reckon it is a normal thing and i do not need to worry about it.?
Old 05-10-2010, 10:29 PM   #4
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
It's completely normal. All you have to do is to let off or press the throttle just a little to dramatically change the mileage at any given instant.
Reddog99 is offline   Reply With Quote
Old 05-12-2010, 03:32 PM   #5
adigilani
adigilani's Avatar
thank you reddog and yarrr for answering my thread.
calculation, computer, consumption, dash, fuel
