Old 05-12-2010, 09:14 PM   #1
drew999
Drives: 2008 yaris
exclamation point
the exclamation point is lit up on my dashboard and wont go away. There's nothing wrong with my tires.
anyone know why its still up thre?
drew999 is offline   Reply With Quote
Old 05-12-2010, 09:23 PM   #2
90tsi
90tsi's Avatar
Drives: 09 yaris
just sayin air pressure is not right.. but if you check them and there fine one of the sensors are bad then. have you put fix-a-flat in them at all?
90tsi is offline   Reply With Quote
Old 05-12-2010, 09:24 PM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
low pressure or you have custom wheels with out the sensor
Originally Posted by sw07gt
Old 05-12-2010, 09:39 PM   #4
drew999
Drives: 2008 yaris
i had a popped tire which i put fix a flat in but then i got all 4 tires replaced with new tires and the ! is still there
Old 05-12-2010, 09:40 PM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
you ruined your tire pressure monitor by using fix-a-flat..... NEVER use fix-a-flat
Old 05-12-2010, 10:38 PM   #6
ah.. a quick question like that..
does insurance say a thing about the tire pressure monitor if an accident occurs? I mean, if you don't give a shit about the sensors, and you know for fact your tires have the right pressure??
Old 05-12-2010, 10:42 PM   #7
90tsi
90tsi's Avatar
Drives: 09 yaris
Xs 10000000
working at big O for the past 2 months and ive bet ive put in 100 cuz ppl put fix a flat in the tire.... its crazy but it eats the base of the sensor and destroys the chip inside.
my buddy at toyota told me a while ago when i tried to help a friend she had replaced one and it wouldnt read the new one, so i tried to get it to program with our tool at work. but the only way is to have the toyota read and program the serial number in.
Old 05-12-2010, 10:46 PM   #8
drew999
Drives: 2008 yaris
so the sensor is fucked
is there anyway to get the ! off the dash ?
Old 05-13-2010, 03:14 PM   #9
b_hickman11
Drives: 08 Sedan
Buy a new sensor and have it installed
Old 05-13-2010, 03:18 PM   #10
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Remove the light bulb behind the !
Old 05-13-2010, 03:22 PM   #11
Rain
help! my Yaris shrunk!
Rain's Avatar
It won't go away until you finish the quest
...which is to get the sensors replaced XD
Old 05-13-2010, 04:01 PM   #12
If you don't want to replace the sensor, you can get rid of the light by doing the TPWS bypass:
http://www.yarisworld.com/forums/sho...light=diy+tpms
Old 05-13-2010, 04:12 PM   #13
Kal-El
Kal-El's Avatar
Wonder if Fix-A-Flat (and similar products) have put a clear warning label on their cans?? Seems like a widespread problem now.
I'm glad I have an '07 which is before law required TPMS's. I know how to check my own pressure.
Old 05-13-2010, 04:15 PM   #14
Kal-El
Kal-El's Avatar
Drive the car 500,000 miles or 20 years (whatever comes first), and hopefully the light bulb will have burnt out.
Old 05-13-2010, 04:37 PM   #15
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
+1
Old 05-13-2010, 04:53 PM   #16
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Stick a piece of black electrical tape over the (!) light.
Old 05-13-2010, 05:39 PM   #17
Rain
Rain's Avatar
Like they say, out of sight, out of mind
Old 05-13-2010, 08:53 PM   #18
wow.. surprised there's a law on that..
Shouldn't the fix-a-flat already have those warnings? if not... i smell court case! well... for a 20-50$ repair.. Hmm.. :P
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
Yaris at Summit Point Time Trials Redbat01 Tracking, Racing, Auto-X Forum 1 05-06-2010 12:30 PM
exclamation point shown on a 2008 toyota yaris sedan dashboard SoundWave DIY / Maintenance / Service 16 06-25-2009 10:49 AM
just got back from cedar point... joey1320 Off-topic / Other Cars / Everything else Discussions 2 06-15-2007 11:01 PM
Friction Point - Clutch hal9000 DIY / Maintenance / Service 17 12-01-2006 03:55 AM
