Old 05-16-2010, 06:27 AM   #1
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
ABS/Brake Lights on
Hi All,
The other day my sub's main power wire got loose and grounded...
Causing a bunch of fuses to below taking out the P/S, Aircon, Indicators, Central Locking, ABS, speedo, etc.
I managed to fix everything except for the ABS. I have tested all the fuses and they arent blowen (although I could be wrong)
Any idea what I could try to fix it?
mick.wheelz is offline   Reply With Quote
Old 05-16-2010, 10:46 PM   #2
If you look at page BC-26 of the Brake Control section of the service manual (which is posted in a sticky at the top of the DIY forum), you can jump 2 pins on the DLC3 (OBD port) to read and then clear the DTCs for the ABS ECU.
Old 05-17-2010, 08:52 AM   #3
mick.wheelz
found the problem, ABS fuse has gone AWOL, not sure how that happened.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
