Old 05-17-2010, 12:00 PM   #1
hatchbackkid82
Drives: .
16x8 Rims w 205/45/16
Hi sorry to sound like a noob, but does anyone know if this will work with out rubbing. 16X8 on 205/45/16. I've tried the search bar and i couldn't find anything. My car is lowered on Tigertecs. I was thinking about these just want to make sure i'm not going to have any fitment issues. Thanks for any help
Old 05-17-2010, 12:25 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
might work for the rear but not front..
Old 05-17-2010, 12:37 PM   #3
hatchbackkid82
Drives: .
Damn!!!!! Can anyone confirm this. It's a good thing i didn't place my order. Yeah i was noticing that a lot of people are running 7 inch wide rims in the front.
Old 05-17-2010, 12:50 PM   #4
33OH
Drives: '08 Yaris
Most likely will rub, but what is the offset?
Old 05-17-2010, 01:07 PM   #5
hatchbackkid82
Drives: .
Uhhhhh I'm an offset idiot. I don't even know sorry
Old 05-17-2010, 01:10 PM   #6
^ should be listed in the wheel specs on whatever site it was you snagged the pic from. Offset number is going to be critical with these wheels.
Old 05-17-2010, 01:14 PM   #7
can't answer the question without the offset -- it's the most important piece of information.
It is possible to fit those wheels to the Yaris, but it has to be done just right, and you will be needing some camber.
Old 05-17-2010, 01:53 PM   #8
coffiend
coffiend's Avatar
Drives: 08 Black LB
8" and a lower offset will rub without camber.
I'm on 15x7 with +15 offset and I even poke a bit up front and rub a little on hard turns.
But, if you want to put in some work with camber you can make it work.
But like Garm said, wiith no offset specs it's impossible to say wether or not they'll fit..
Old 05-17-2010, 03:00 PM   #9
hatchbackkid82
Drives: .
Here is what i found offset is 0
Specifications
Wheel Size 16x8
Color Gun Metal
Bolt Pattern 4-100/114.3
Offset 0
Lip Size 3.5"
Required Lug Nuts Tuner Style
Old 05-17-2010, 03:06 PM   #10
+0 on a 16x8?
definitely POKE, you'd need a serious stretch tire to make that work.
Old 05-17-2010, 03:11 PM   #11
hatchbackkid82
Drives: .
so a 215 /45/16 tire wouldn't work then right? it would rub.
Old 05-17-2010, 03:12 PM   #12
hatchbackkid82
Drives: .
I really don't mind if rims come a lil far out i'm more worried about it rubbing the cai or the fender liner
Old 05-17-2010, 04:07 PM   #13
yeah you are probably looking at a 195 stretched to make that work.
Old 05-17-2010, 06:46 PM   #14
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
you would be better off with the 16x7 +38 version with a 205/50 or 205/45... though a 15x7 might look better, and would defiantly be lighter.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-17-2010, 10:17 PM   #15
kimona
kimona's Avatar
Drives: 2014 White VITZ
16x8, ET0, 195's? Good luck, mate! That'll be somewhere between tough and impossible to fit AND look right.
Old 05-17-2010, 10:57 PM   #16
^ I think that stretch with ---camber would work. It's not a look I would go for, but that's not the point.
Old 05-18-2010, 12:59 AM   #17
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Don't do it... unless you have Garm's fender flares
Old 05-18-2010, 07:45 AM   #18
33OH
Drives: '08 Yaris
Herb, I'd stick to a 16x7 with +35 offset to +40 unless you want to do some major trial and error with tire sizes and rubbing.
WTB: 4 15" alloy rims _Bravo_ Willing to Buy by private party 2 02-19-2010 06:39 PM
Looking for 15 inch stock steel rims hop Canada 2 01-21-2010 07:18 AM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
