Old 05-19-2010, 02:01 PM   #1
finnpoulsen
Drives: yaris 2sz-fe
Spark plugs part numbers?
I'm about to replace my spark plugs and I went to http://www.toyodiy.com to get the parts number. I can see I got two types to choose from, what is the difference and which is the best?
http://www.toyodiy.com/parts/p_E_200...MRKW_1901.html
finnpoulsen is offline   Reply With Quote
Old 05-21-2010, 09:54 PM   #2
severous01
go get some ngk's from oriley or autozone.
Old 05-22-2010, 09:26 AM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
How many km, on the plugs? in the US we have Iridium plugs in the 1NZ 1.5L engine and they (purportedly) last over 100k kilometers. I would say a denso or NGK iridium would work well for a COP ignition. Is yours cop?
Old 05-22-2010, 03:22 PM   #4
ri_espinosa
ri_espinosa's Avatar
Drives: Toyota Tercel
Send a message via MSN to ri_espinosa Send a message via Yahoo to ri_espinosa
http://sparkplugs.com/
ri_espinosa is offline   Reply With Quote
Old 05-22-2010, 03:29 PM   #5
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
the 90080-91229 (L)
is the same as 90919-01176 (J)
as you can see they are the same (K16R-U)
all depends if your car is manufactured as (L) or (J)
(L)ocal or (J)apan SPEC
It wont matter which you put in except the saving of the 72cents
the're both DENSO brand
If your VIN starts with (J) japan
If it starts with a # its (L) local
go figure
hope this helps
OTA'sTOY is offline   Reply With Quote
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 01:33 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
Help Finding part numbers PLZZZZ!!! Duckywitbigfeetz Cosmetic Modifications (Exterior/Interior) 0 07-29-2006 02:21 AM
