Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 11-26-2006, 10:16 PM   #1
ASHRAF
Scubie Du
Drives: '10 SWP STi/'09 Escalade
Send a message via AIM to ASHRAF Send a message via MSN to ASHRAF Send a message via Yahoo to ASHRAF
fog lights to be installed in Perth, Please help
Hi everyone,
I recieved my foglights se for my toyota yaris
and i want to install them as soon as possible
need some place for proffesional installation
I live in Bentley, please help me to find someone to fit it with nice price
regards,
Ashraf
ASHRAF is offline   Reply With Quote
Old 11-26-2006, 10:39 PM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
You can install it yourself, though u just need to take off the front bumper and just rewire it.......
or go to your local toyota dealer.....
Old 11-27-2006, 01:50 AM   #3
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
Where did you pick up a set of fogs in Perth, or did you get it off EBAY?
If I had or found a way to get a pair of fogs I would get it installed it at either AutoBahn or XSpeed.
DollaZo is offline   Reply With Quote
Old 11-27-2006, 06:33 AM   #4
ASHRAF
Scubie Du
I GOT THEM VIA EBAY BRO
I'LL TRY WHAT U'VE SUGGEST
SEE YA
Old 01-06-2007, 08:40 PM   #5
Speedz
Will work for Yaris...
Speedz's Avatar
Hows did the foggies went?
Where did you get it installed?
Pics please.... :D
Speedz is offline   Reply With Quote
Old 01-07-2007, 12:53 AM   #6
ASHRAF
Scubie Du
it is really nice but i almost got a ticket switching them on without foggy weather
I am new here in Australia an If I knew this is the case I would've save my money
back home i don't swich off my foggies at all
i installed at Bentley Auto Electrics
here are some pics
see ya
Old 01-07-2007, 11:24 AM   #7
Speedz
Speedz's Avatar
Ah nice...
If you ever consider HIDs you gonna have to change those bulbs to match the color of the HIDs...
How the beam look like...? Pencil beam or does it spead widely and lit up the area where the normal beam doesnt lit up?
Coz I'm thinking about getting one for a while already...
Does yours include the fog light covers? They cost $45 bucks quoted OEM...
And how much did it set you back for the installation cost?
Cheers
Old 01-08-2007, 09:01 PM   #8
ASHRAF
Scubie Du
the price i pay is just for the set and wiring
they face a problem with the wiring cause the end was not the same as the genuine
so they have change the wiring some how to fit the car
i don't acyually remember how much did it cost me to install them
but it was extremly expensive job
by the way
are there H11 Bulbs 6000K?
and where can i found them?
Old 01-09-2007, 11:17 PM   #9
sewid
Aussie Yaris Nut
Drives: AUSDM Yaris YRS
I got a set of these off ebay and installed them myself. It took about 3hrs all up because of the amount of stuffing around you have to do to get to the wiring near the ECU.
You don't need to remove the front bar to install these at all. I just unbolted the splash guards and inserted the flights in from behind. Only 1 screw needed per side to bolt them in. Quite well engineered there.
Running the wiring and switch is very straightforward and 99% of the panels on the interior you have to move are just clipped in and come off by hand when coaxed gently. One bolt is removed for the entire central/rear console in order to route wiring nicely.
The hard part is using the quick connectors on the ecu wiring. Firstly its impossible to see the wires. You have to use a mirror to find the wires. Next they are taped together so you have to remove the factory tape somehow. I used a scalpel and a mirror and some strange awkward hand movements...
Eventually you find the wires and then you have to stuff around some more and click the quick connectors on to them, all while using a mirror to see wtf your doing behind the dashboard... This is the worst part by far.
The kit I had also had poor instructions with respect to which wire went where behind the ECU.
They said:
Connect wire (B) to purple wire. Then connect wire (W) to purple wire.
I had a blue and a green wire ... which out of B and W is Green? Well if you guessed "W" since "B" means blue you'd be wrong. Apparantly B means Green and W means blue........
Anyway im confident i could do it again in half the time knowing the ins and outs now.
sewid is offline   Reply With Quote
Old 01-10-2007, 09:39 AM   #10
ASHRAF
Scubie Du
good on u m8
hope u was there for me hehehe
Old 01-13-2007, 06:54 AM   #11
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
are these the ones you bought?
FOG LIGHTS
as400g33k is offline   Reply With Quote
Old 01-13-2007, 09:54 AM   #12
ASHRAF
Scubie Du
they look the same as400g33k
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 3 10-20-2008 05:36 AM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 10:48 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
