Old 05-20-2010, 10:27 AM   #1
shangapol
Drives: Yaris Sedan
Question PLACE TO MY AMP YARIS SEDAN
HELLO PEOPLE,
I have this AMP: JBL GTO5355.(Length 472mm, Width 264mm, Depth 54mm)
Where can I put this AMP in my YARIS SEDAN?.
Where can I put the cable that goes to the battery??.
How I can pass the power cable, from the battery to the amp??
There any instructions to install components 6 1/2 in the front doors??
Where do I place the tweeters?.
A few question, please help me with this.
shangapol is offline   Reply With Quote
Old 05-20-2010, 11:52 AM   #2
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Originally Posted by shangapol View Post
HELLO PEOPLE,
** Possibly under the passenger seat.
** See below.
** I used the rubber grommet on the passenger side firewall about where your left foot would rest. Pull back the carpeting to see it. It's the vent hose for the A/C. Then use zip ties in the engine compartment to keep the line away from the exhaust and route it to the battery. Use a fuse block before connecting to the battery.
** Not really. However, there are several active threads right now that have suggestions, see DerickVeliz2 thread about sound deadening. He has tons of pictures to view. You will probably need speaker adapters as well.
** I'm thinking in the little black plastic panel in the front corner of the window. It should be pretty easy to pop out and drill the right sized hole. Do this with the door panels off.
I'm sure others will add their suggestions too!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 05-20-2010, 12:01 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
I have mine under my passenger seat but if I i could redo it again i would have it mounted behind the the rear seat in the trunk. Under the passenger seat dosnt seem to be much ventilation and its annoying having the fan come on when the music is low.
Old 05-20-2010, 12:23 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Up at the top of the page when you enter this lobby there's a Topic that says " DIY amp wire running and radio trim removal" You may want to start there .
http://www.yarisworld.com/forums/showthread.php?t=26407
Second set of pictures you can see how i did my 6.5's and the trunk area is ...a work in progress...just wanted to get everything in.
amp, cable, jbl, sedan, tweeter
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
How much did you pay for your yaris sedan? Where is my Yaris? New YARIS Purchase Forum 5 03-27-2007 06:16 PM
