#1 |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
First Tank MPG
I finally decided to put gas in the Yaris for the first time, and it got around 37-38 MPG, depending on when it was filled between 0 to 10 miles, and how full the dealer got it. That's a month of in-town driving 3-6 miles at a time, including some break-in zoomyness, and about 25% highway miles today at 50MPH, plus I drove a very twisty mountain road about 15MPH from 4000-6700 feet elevation with more than a dozen stops on the way up and engine braking all the way back down. With so much uncharacteristically wasteful driving on the first tank, this should be the worst MPG my Yaris ever gets...
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
It sounds like you're off to a great start.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#3 | |
Audio Junky
#4 |
The road up Mauna Loa has a fairly shallow slope and is very twisty with hairpins, so I was working the clutch and brake a lot. There's also a tiny bit less oxygen up there.
Where I really gain MPG is on the main highway up and down Kilauea, which has just the right slope for many miles of coasting on the descent. It also helps that (mature) people don't mind going 5-10 MPH under the speed limit here. ;) In road-raging Colorado I would have been run off the road. I've been able to get 45 MPG in the FX-16 on a double round trip up and down Kilauea, which is better MPG than on flat land. |
#5 |
![]() Drives: 2010 Yaris 3-door LB (MT) Join Date: May 2010
I just filled up after my first tank yesterday. I drove 384.5 miles using 10.3 gallons of gas, which is about 37.3 MPG total. I had a mix of driving, with about 70/30 highway:city driving and plenty of hills, and with some stop-and-go traffic. I'm also changing my speeds frequently to break in the engine according to the manual, so sometimes on the highway I'll go down to 50mph and then I'll slowly accelerate to above 70mph. I imagine I'll probably be averaging in the 40+ mpg range long term, which I'd be quite happy with.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
you're in the normal range .
#7 |
hard to go by the dealer fill . Not known if under / over filled . Our 1st tank in the '08 auto sedan netted us close to 44 . My guess is that it was overfilled . I always stop the fillup at 1st click of nozzle at high flow of the pump . Came close to the 1st fill a few times since .
#8 |
Second tank was 35.9 MPG, but I had a fair amount of heavy traffic and some air conditioning use mixed in, so all in all that's not so bad I think.
#9 |
My second tank got combined 41MPG, with 75% highway (50mph) with gusty winds, and 25% short 2-6 mile town trips. I suspect the town portion sucked down more than its fractional share of the gas, but if I ignore that suspicion and just apply simple algebra to the two fillups I get 36 MPG town and 43 MPG highway. I suspect in reality the former is a little less and the latter a little more. I could get up to 45 MPG on that highway trip with the old corolla, and it looks like the Yaris is identical. I was surprised to notice on the long trip that the Yaris does not coast quite as far or as fast downslope as the old corolla did. 50MPG seems like it will be more difficult than I anticipated.
#10 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
The old Corolla most likely didn't have DFCO. When the car's coasting with the fuel completely shut off, the engine drags the car down faster than when it's got idle fuel flowing.
#11 |
coasting == neutral The downhill slopes on this particular highway are shallow enough that I need to keep every iota of momentum, and then give it a bump of gas on the flat spots every few miles.
#12 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
^ I have to do the same on certain highways!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#13 |
To be fair I got 45 MPG in the corolla back when I briefly got stuck with a ricer "high-flow" muffler. More like 43 before and after. The winds can be pretty hellish on that road.
I do think a steeper climb might yield greater MPG round-trip. |
#14 |
![]() Drives: 2010 Toyota Yaris 2dr HB Join Date: Jun 2010
Topped off my dealer fill, then drove 1/2 a tank...filled up again
39.4 mpg - 90% highway not bad for a start! Tried a little DFCO, etc...mostly just driving a bit slower at 65-70! |
#15 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
i just measured my first tank. it was mostly highway and the ac was on 100% of the time. it came to 38.55. i'm very pleased and i think the next tank will be even better because about 3/4 through the tank i finally checked my air pressure. the tires were anywhere from 25 to 30 psi. i pumped them up to 42 and also switched to mobil 1 5w30. i hope to get over 40 now. these cars are amazing for mpg.
#16 | |
"LibertyRides!"
Excellent! You should be on your way to 40+ mpg.Let us know how things go... Cheers!
#17 |
A bit different combo on fillup #3 - 60 miles of 3-5 mile trips, then a 110 mile highway (50MPH) trip. Some strong head/crosswinds on the return leg, but much of that while downhill coasting. 43.6 MPG. I must have been over 45 MPG on the highway. <geek>Now I need to find a least-squares program to help me break down the town/highway components. </geek> That's probably my final MPG update post in this thread.
#18 |
![]() Drives: Looking to buy Join Date: Sep 2010
I picked up my new Yaris last night & took a trip today. LOTS of VERY twisty mountain roads, including several ~15 mile stretches never out of 3rd or 2nd gear.
My first gas up showed that I got 44.2 mpg. It's brand new too so it's not broken in yet. Figured I'm doing a good job of breaking in the engine with all the ups & downs, accell & decell. Robert in the hills of Tennessee |
| Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 11:49 AM |
| first tank: 42 mpg | rtom | Fuel Economy Forum | 4 | 01-05-2010 02:14 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
