Old 11-27-2006, 07:11 PM   #1
uncleyaris
stock system
Anyone know who makes the stock systems for Toyota? Asking cause I wonder if replacing stock speakers is worth it if the head unit is just poor to begin with?
any feedback appreciated!!
UY
Old 11-27-2006, 07:21 PM   #2
eflb55
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US)
i wanted to change my stock speakers recently but i decided to just to get a new head unit because having to use a line out converter for the stock to connect to the speakers takes alot of quality out of the music. just having presets and an equalizer in an aftermarket stereo can make alot of difference.
eflb55 is offline   Reply With Quote
Old 11-27-2006, 09:37 PM   #3
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
I replaced the fronts with some infinity 3 ways still have the original headunit. Sounds much better. I was suprised to see the stock speakers are made from plastic
tiksman is offline   Reply With Quote
Old 11-27-2006, 11:55 PM   #4
the OEM unit is made by FUJITSUTEN and is stable at 2ohm. a rarity really...
Old 11-28-2006, 12:31 AM   #5
spkrman
Drives: 1
A new head unit will make a big difference, but the stocker isn't all bad.
New speaks are a worthy upgrade, though.
Old 11-28-2006, 12:33 AM   #6
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
wow, fujitsu ten makes some pretty good head units (Eclipses). i thought the yaris head unit would have been made by pioneer, since the stock JBL 6-disc head unit from my '06 sienna is made by pioneer (even has a "DEH" designation on the backside), and the head unit looks almost identical to every other head unit in toyota vehicles, even down to the button placements and illumination. i switched the pioneer out with a toyota factory fujitsu ten navigation system from a 2007 solara, and the sound got even better (pretty good to begin with, for a factory system inside of a van). knowing that it's a fujitsu ten head unit, i think doing a speaker swap with the factory head unit will yield better results than doing a head unit swap with the factory speakers.
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline   Reply With Quote
Old 11-28-2006, 03:39 AM   #7
spkrman
Drives: 1
well, I head unit swap with the factory speaks yeilded much better results for me :).
I also added a set of tweeters up front, which made a drastic difference.
Old 11-28-2006, 08:14 PM   #8
atebit
I recently replaced the HU & both my front & rear speakers on my 07 sedan with some low-mid level JBLs. I think it was worth it. First of all the factory speakers are made of plastic and cardboard...no metal at all, except maybe the magnet. The maget is a joke as well...it's about the size of a dime.
While I am by no means looking for audiophile sound in the Yaris, I think the speakers make a big difference.
atebit is offline   Reply With Quote
Old 11-29-2006, 05:17 AM   #9
the OEM HU is really good, except it's not very powerful.
toyota use pioneer in every other cars that isn't powered by futjisu ten. ie, scion and are a tad more powerful.
Old 11-30-2006, 10:54 AM   #10
but, the BOSE system in my dad's maxima is also made of paper cone??!
Old 11-30-2006, 11:36 AM   #11
boris13
Drives: 2007 Yaris Liftback, 5-speed
I have seen references in this section about the ability to use 6.5" speakers in the rear of the liftback as well as in the front. A reference was made to using SAT6 bracket adapters, which I believe are made by Scosche. There was something said about new holes needing to be drilled to make it work... would that mean drilling new holes in the bracket or in the car itself?
I want to use Alpine Type-R SPR-17LP (Type R) speakers in the front and Alpine SPS-17C2 (Type S) speakers in the rear. I may add a small amp like the Alpine MRP-F250 (40 watts RMS X 4 at 4 ohms) for a modest upgrade.
I'd like the opinions of the audiophiles here on this. Remember, I'm not looking for a killer, loud system; just a nice, good-sounding upgrade with a little more power.
boris13 is offline   Reply With Quote
Old 11-30-2006, 01:03 PM   #12
ChinoCharles
Drives: LB
Sounds like a super solid system on a budget. Should sound 1084762995 times better than stock.
And way to choose Alpine.
Old 11-30-2006, 06:46 PM   #13
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
I'm having a f*^ing hard time to fit some infinity's 6.5.
The tweeters don't fit, and the door cover hits the tweeter..I torn aparte the crappy stock speaker, and used it as spacer...but it's too thick..
i'm trying to have some fabricated in order to fit the speaker, without forcing the tweeter against the door cover..
Yaris-TJ is offline   Reply With Quote
Old 11-30-2006, 08:44 PM   #14
Yaris-TJ
Yaris-TJ's Avatar
what I think I can do, is dremel off, the extra thickness...
Dremel man ! Dremel man!
BTW, in order to get metal spacers for the back 6x9 on the sedan..you can also Dremel...Dremel!
Old 12-01-2006, 12:15 AM   #15
johnnyfive
johnnyfive's Avatar
well, what i did was just zip-tied some 6.5's i had laying around into the stock brackets, and zip tied the backets to the doors...
zip ties man, zip ties :)
i know, i know, only till i get cash to get something to make me happy, and i didnt feal like doing it right, but i must say that it really did turn out well, and sounds way better than stock.
Old 12-01-2006, 12:23 AM   #16
dremel, swiss army knife, zip ties, duct tape and WD-40
with just those things in your tool bag you can fix/modify/create just about anything
Old 12-08-2006, 08:08 PM   #17
Yaris-TJ
Yaris-TJ's Avatar
Zip ties come really handy when installing your audio cables...when you get in your trunk all 4 speaker cables + 2-rcas +powe,groung remote, zip ties do all the work for you!
Old 12-14-2006, 10:44 PM   #18
uncleyaris
thanks for the heads up everyone!!!
Uncle
Stock 6 disc MP3 deck + speakers for sale!!! chino_potato Items for Sale by private party 16 02-05-2009 07:27 PM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
Fiberglass enclosure / Stereo system bugnuts In Car Entertainment + Electronics (audio / video / alarm) 30 05-20-2007 12:11 PM
Immobilize and security system. Meow In Car Entertainment + Electronics (audio / video / alarm) 19 04-18-2007 05:40 PM
wtf want to replace stock stereo gichlid In Car Entertainment + Electronics (audio / video / alarm) 5 09-06-2006 12:40 AM
