Old 06-03-2010, 08:49 PM   #1
coffiend
coffiend's Avatar
Drives: 08 Black LB
For tjos who have baked/painted headlights...
*edit - sorry for te typo in the subject, posted from iPhone.
I'm thinking about diving into this project over the weekend.
I'm just looking for some tips from those who have done this mod...
Here's a list of some Qs I have...
Oven temp / time - 250 ish for about 4 min?
What grit of sandpaper to scuff sand the chrome to be painted?
Do I need high temp paint? ( I have HIDs )
what should I use to re-seal?
Once the sealant is applied, do I need to stick them back in the oven for a short time to let the adhesive fill any small holes I may have missed?
Any answers to those Qs or any tips / pointers would be GREATLY appreciated.
Old 06-03-2010, 11:24 PM   #2
Brian
Brian's Avatar
Try 200-210 for 7-10 min. Wrap a cookie sheet in foil and put the headlight on top. Make sure the light is as close to the middle of the oven as possible. Check every couple of mins. Removing all the old sealant is a good idea too.
I used 600 grit
No. I always use SEM brand paint. Use an adhesion promotor before primer. It makes the paint stick better.
The best thing to use is the OEM Nissan sealant. Seals better than almost anything else.
No, but it softens the sealant making it easier to get the lens nice and flush. Make sure to either clamp or wrap some masking tape around the headlight to hold it in place until the sealant cures.
Old 06-04-2010, 01:39 AM   #3
coffiend
coffiend's Avatar
Drives: 08 Black LB
Thanks alot guys really good feedback it helped alot.
Sobi would assume you can just get the nissan sealant at any Nissan dealer?
Old 06-04-2010, 07:44 AM   #4
Brian
Brian's Avatar
Yes, I can get the part # when I get home. Its about $15 and is enough to do about 4 headlights.
Old 06-04-2010, 01:32 PM   #5
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
i opened mine with a hair dryer lol BBQ paint no clear.. putting them back together with out niking the pain was a bit of a pain
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Sedan Headlights looklike lexus LS monchito18 Cosmetic Modifications (Exterior/Interior) 2 08-10-2009 07:06 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
