Old 06-04-2010, 12:57 PM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Fog light switch
So for those have bought aftermarket fogs and installed them themselves, I was thinking about changing the switch. Has anyone done that? Is it hard? I looked at the plug of stock switch and it looks like I would just have to take the wires from the stock one and put them on the new switch.
Any tips would be great!
Thanks
Old 06-04-2010, 01:05 PM   #2
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
I changed mine to a small black toggle switch. Nothing fancy, just on/off. I used a dremel tool to fit/clip it into the placeholder next to my shifter. I like it. I'll take a picture later.
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Old 06-04-2010, 04:19 PM   #3
yarr_is
Drives: yaris
Not hard at all.. just wire it up and you're done. Just make sure it fits. And like said above dremel.
Partially Sponsored by:
Tanabe USA
yarr_is is offline   Reply With Quote
Old 06-04-2010, 04:32 PM   #4
Here's mine:
If you go for a lighted switch, make sure that the light is separate from the switch contacts. Then, you simply connect to switch contacts to the yellow and orange (or beige) wires of the headlight stalk and connect the light to dimmer (either at the shift illumination or at the dimmer rheostat).
Old 06-04-2010, 06:48 PM   #5
falkor_99
falkor_99's Avatar
Thanks everyone =D
Old 06-04-2010, 08:03 PM   #6
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
I personally don't like that.
I replaced my turn signal/headlight stalk with a similar switch with fog light control. This makes it a true factory install with, and NO cabin or firewall entry is needed for the wiring.
Meteorite_Marty is offline   Reply With Quote
Old 06-05-2010, 03:58 PM   #7
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
How much was your oem stalk with foglight switch? I'm getting my fogs soon, and I'd like OEM controls, but I don't want to pay more for the switch then I did for the fogs ($100) ...
Old 06-11-2010, 10:22 PM   #8
Meteorite_Marty
Switch was around $75 I think.
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
fog light switch Creeper Willing to Buy by private party 8 05-21-2009 08:26 PM
Fog light style switch for added lights Arkhangel Cosmetic Modifications (Exterior/Interior) 10 03-16-2009 10:08 PM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
