Old 06-05-2010, 09:48 AM   #1
bankrobber
Drives: 2007 Yaris Hatchback
when to replace rear drum brakes
Have 90,000 miles probably half are interstate miles. So I bought new shoes at Peb Boys and the new ones look close to thickness of old ones. I know to replace at 1/16 inch. The new shoes are same thickness as two quarters and old ones are slightly lower than two quarters. Can I run shoes down to one quarter's width?
Old 06-05-2010, 10:10 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Yes, as long as any rivets aren't yet touching. Conventional wisdom is at least 1/32" clearance for rivets. You've probably got bonded linings, I haven't looked at mine.
Old 06-05-2010, 10:59 AM   #3
bankrobber
I never done drum brakes so when I first saw how thin they were I thought had to replace them. The new ones look like about 3/16 of an inch. I probably have 1/8 left
So I just sprayed everything down with brake cleaner. I was getting a short squeak sound when applying brakes.
Old 06-05-2010, 11:27 AM   #4
Yaris Hilton
Smile
Usually means some sort of contamination or rust.
Old 06-05-2010, 07:34 PM   #5
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
A rule of thumb I was given by a mechanic-if the parking brake is working good and holds the car then the drums are fine. I've stuck to this theory and never had a problem even on an old wrangler with over 130k on it's rear drums.
Old 06-05-2010, 09:24 PM   #6
Yaris Hilton
Smile
That's certainly true. But when the parking brake gets loose it doesn't necessarily mean you need the rear brakes redone, you may just need to tighten up the cable a bit.
Old 06-05-2010, 09:38 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
keep rollin on the stock shoes, sounds like you got plenty of meat left
Removing drum from rear axle bankrobber DIY / Maintenance / Service 20 07-01-2010 04:24 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
