Old 06-06-2010, 01:04 AM   #1
big lo
big lo's Avatar
Drives: 2007 VIOS
MI projector foglights
Has anyone brought these lamps and if theres some special mods I should know about before any purchase. I will be using a HID H3 kit for them to work. Just to see if theres any mods for instalation these fogs.
Old 06-06-2010, 01:09 AM   #2
Brian installed them, see if you can hit him up for advice. his username is "brian"
Old 06-06-2010, 01:22 AM   #3
Brian
Brian's Avatar
You need to trim the reflector housing a little bit for the projector to sit a little lower. I'm working on a pair of lights now so I can post some pics of them tomorrow of where to trim.
Old 06-06-2010, 03:36 AM   #4
^ that's for the bolt on headlight projectors
OP wants to know about the foglights that you also have and installed.
Old 06-06-2010, 02:03 PM   #5
Brian
Brian's Avatar
Sorry, I overlooked the foglight part. They don't need any modification. Just bolt them on and wire them up. The instructions aren't in English but the pics are very good and easy to figure out.
Old 06-06-2010, 04:00 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
Thanks brian, thats really cuts down on work for me, but I think you meant the projector H4 retrofit and that info is very important to me as well, were do I cut etc. Hit me up when you can. Good looking on the info.
Old 06-06-2010, 05:30 PM   #7
Vang
Drives: 2008 Yaris Sedan
does the shroud fit perfectly?
Vang is offline   Reply With Quote
Old 06-06-2010, 07:04 PM   #8
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
I am doing the H3 to mine and I haven't had any problems with them at all.
Old 07-14-2010, 10:59 AM   #9
big lo
big lo's Avatar
Drives: 2007 VIOS
Thumbs up
I must say the projectors fogs, are very good in quality, and it doesnt, have light pointing in different directions either, you can point them were you need it most. I am very pleased with the out come of these lamps, thank you Garm, holla at me.
