Old 06-07-2010, 10:58 PM   #1
Goose
Car Geek
Drives: Yaris Liftback
Tire suggestions?
I've been reading old threads on tires, and wanted to collect opinions/suggestions on what to get.
I think my car's highway behavior will be improved by new tires. The way my car tramlines and seems to "wallow on its tires" drives me nuts. Rather than mess with my car's suspension (yet), I'm going to replace the crappy OEM Goodyears. I'm going to stick with the stock steelies and keep the same 185/60 R15 size.
My primary interest is getting crisp steering response, followed by good all-weather (ie snow) performance. I don't necessarily need super-long tread life. I'm trying to avoid a tire with soft sidewalls, since I think this would cause the wallowing/tramlining I'm getting with the Goodyear's (does this sound right?).
I assume that Michelin Harmony's are still the favorite all-around choice. The TireRack reviews are also good for the General Altimax HP's, Pirelli P4's and Yokohama AVID touring's.
Those that have experience with these tires, can you share your experiences?
Kevin
'07 Blazing Blue 5-speed liftback (sold)
'08 Black auto liftback (sold)
'09 Carmine Red auto 4-door liftback (sold)
Goose is offline   Reply With Quote
Old 06-08-2010, 10:16 AM   #2
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
It's too bad your car did not come with the Bridgestone Potenza RE92-I've put about 40K on them and they are quiet, never wallow, nor follow rain grooves. They are stiffer in the sidewall and give a good turn-in and maintained perfect balance. All that said and now I'm sitting on the fence wondering what to try next in my OEM size. Looks like the Harmony-but I am nervous about the turn-in as these are not performance tires like the Potenzas. With all the bad reviews you'll read about the Potenzas I actually liked them quite a lot and still think-well, I liked the way they drove and handled enought when new to buy the whole car they were put on. Several people have liked the Yokahama TRZ's-but I don't like the styling of the sidewall.
Old 06-08-2010, 11:04 AM   #3
severous01
if you want a good 'crisp' feel, get runflats. the sidewall is super stiff and wont flex under turning loads. otherwise, step up to a 195 series for a much better pick of different tires. 185 is an econobox tire only.
Old 06-08-2010, 02:57 PM   #4
Goose
Car Geek
Thanks for the replies, guys.
I went to my local Sears and bought a set of Bridgestone HP550's in the 195/60 R15 size. The HP550's appear to have a good tread and seem to be more performance-oriented than the OEM Goodyear's.
After driving a few miles on a winding country road with the new tires... I'm not sure if I didn't just waste money. I'll wait for a while before drawing my final conclusions, but here are the first impressions:
1) Straight-line tracking may have improved slightly.
2) There is now an faint oscillating sound between tires and engine @60MPH (may go away as the tires break-in).
3) The car handles badly through sweeping turns. It feels like the sidewalls want to fold under the wheels in the turn. Hopefully this will also improve as the tires break-in.
4) I knew that the diameter would be greater with the new size, but now it looks like I've got dune-buggy tires (high sidewalls) compared to what I had. Not good.
This isn't fun...
Kevin
Old 06-08-2010, 04:59 PM   #5
ddongbap
195/60R15 seems like its the wrong size. They're kinda big.
Get these:
http://www.tirerack.com/tires/tires....omCompare1=yes
or
or
http://www.tirerack.com/tires/tires....=Potenza+RE-11
or
http://www.vulcantire.com/azenis_rt615k_t.htm
And I'm sure you wont have any other issues.
The side wall bending wont get better btw. It'll end up getting worse.
Those are a little bit less.
Old 06-08-2010, 05:32 PM   #6
Goose
Car Geek
Thank you for the links.
I'm sure those tires are great (they certainly look cool), but I'm trying to stay with one set of all-seasons. I know that more specialized tires perform better than all-seasons, but I don't need super-high grip. Snow traction is important, too.
Kevin
Old 06-08-2010, 06:05 PM   #7
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Biggest problem you have is sidewall height. 60-series tires are going to flex A LOT. Run your tire pressure a little higher, and maybe get a performance alignment, but don't expect too much from them.
Old 06-09-2010, 05:54 PM   #8
Goose
Car Geek
Well, I took advantage of the 30-day trial period and dumped the HP550's. Couldn't get past the weird handling on these bigger tires. For an extra ninety bucks, I've ordered some General Altimax HP's (H-rated) in the stock 185/60 size. I'm hoping that, by conceding a little snow performance, the General's will be an improvement over the OEM tires. Hopefully my car won't be sliding all over the place this winter.
I'm also looking at rear bars... Thanks for the suggestions. I'll be sure to share my experience with the new tires once I get 'em installed.
Kevin
Old 06-10-2010, 12:02 AM   #9
ddongbap
I don't think that the sidewalls on crappier tires is gonna really matter. If its crappy, its gonna be crappy even if they're 45s, IMO.
Old 06-10-2010, 10:13 PM   #10
trx73
Drives: 2006 Toyota Yaris Silver Hatch
195 50 16 or 205 50 16 tires???
Have 16 x 7 rims with a 38 offset, which tires do you recommend???? 195 50 16 or 205 45 16 or 205 50 16. I am not lowering the car this year but I need tires. I am worried about too much gap or rubbing if I go the bigger tire??
trx73 is offline   Reply With Quote
Old 06-11-2010, 12:28 AM   #11
ddongbap
Is the gap the only thing you're worried about? Do you want grip? Or a stiff side wall that doesn't go limp during a turn? I hate limp noodles.
Old 06-11-2010, 06:24 PM   #12
trx73
Obviously I want both, but also care about the appearance.
Old 06-11-2010, 06:32 PM   #13
ddongbap
Are you lowered?
Old 06-11-2010, 06:34 PM   #14
trx73
no, probably won't for some time
Old 06-11-2010, 06:47 PM   #15
ddongbap
IMO, just deal with the wheel gap. Unless you're going to lower. You're going to have to deal with other crap otherwise.
Old 06-11-2010, 06:54 PM   #16
trx73
205 45 16 will fit best with a 38 offset on my car
Old 06-11-2010, 06:55 PM   #17
trx73
sorry just want to make sure before I buy tires. Have you heard anything about a brand called "Achilles"??
Old 06-14-2010, 11:34 AM   #18
kimona
kimona's Avatar
Drives: 2014 White VITZ
With 16x7, ET38-40, I would recommend 195/50/16, which is OEM size.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
