Old 06-11-2010, 07:29 AM   #1
Gatoblanco
Drives: 2006 5 dr yaris hatch
exhaust tip thats not loud and available in aust
can anyone recommend an exhaust tip for hb that looks cool but is not loud and that is clamp-on and that i can get in aust or easily get to aust?
thanks
Gatoblanco is offline   Reply With Quote
Old 06-12-2010, 10:58 AM   #2
dean_park
Drives: 2011 VW Golf TDI
http://shop.microimageonline.com/Hel...tip-hket-1.htm
it's a clamp on, it's not too loud and I think Garm ships to AUS.
dean_park is offline   Reply With Quote
Old 06-12-2010, 12:51 PM   #3
severous01
magnaflow universal series. i think you should look into the 14xxx series. or maybe 18xxx idk. dont remember.
tone is low, not loud or overpowering...and looks great.
Old 06-13-2010, 04:43 AM   #4
yaris2010RS
yaris2010RS's Avatar
CANADIAN TIRE! a tiny bit louder(nothing very noticable) and under 40 bucks.
Old 06-13-2010, 09:13 AM   #5
Bella
Bella's Avatar
Drives: 06 Yaris YR Hatch
thanks
Have you tried Super Cheap/Repco/Autobarn? They usually stock tips that aren't too expensive - Not sure about clamp-ons though. Otherwise, just head down to your closest exhaust place and get them to replace the tip. I got mine replaced with something a bit less tacky than the stock one (no change in sound, just a bit bigger and more visible chrome) and it cost me about $35 including fitting - They had to cut the stock tip off a bit to get it sitting right, but all up it only took about ten minutes.
Bella is offline   Reply With Quote
Old 06-13-2010, 01:16 PM   #6
The tip shouldn't make much difference in loudness.
Old 06-13-2010, 08:06 PM   #7
1NZYaris1
1NZYaris1's Avatar
+10 on that
the tip will not icrease or deacrease the loudness
unless you add or remove , or inlarge the excuast pipe
back too the muffler .
Old 06-14-2010, 12:15 AM   #8
Gatoblanco
not interested in hellokitty so still looking. no walmart here.
i have seen some tips advertised as having some effect on exhaust tone.
will check out repco etc and failing that i will go to a muffler shop
Old 06-14-2010, 06:17 PM   #9
1NZYaris1
1NZYaris1's Avatar
Super Cheap have some nice ones as well
