Old 06-13-2010, 07:50 AM   #1
syntax
syntax's Avatar
K&N CAI
hello everybody i would like to ask or get your advise if the K&N air intake system for 1.5L would fit for 1.3L engine, thanks
Old 06-13-2010, 04:18 PM   #2
What 1.3L engine? The brand new one, or the 2NZ-FE?
Old 06-14-2010, 05:15 AM   #3
syntax
syntax's Avatar
i have 2010 yaris sedan, also i saw one short ram intake for mazda 626, the shop said it would fit the yaris sedan, we tried to test fit it, but i'm afraid it would create problems, there are no upgrades for yaris sedan here at saudi arabia,
Old 06-14-2010, 05:22 AM   #4
If you can keep that flexible tube and the part into which the MAF screws in, you could use pretty much any aftermarket filter...
Old 06-14-2010, 05:34 AM   #5
syntax
syntax's Avatar
@etimago, do you mean that i can just attach any aftermarket filter? provided that the part for the maf and the other small tube remains intact?
it would not create any problems?
i'll check it now if it can be done....
thanks
Old 06-14-2010, 06:01 AM   #6
Actually... my bad, I forgot that the MAF holder is part of the original intake box... scratch that, then :(
Old 06-14-2010, 07:32 AM   #7
syntax
syntax's Avatar
ahhh i see ... just checked it is part of the original, any suggestions then? there are no aftermarket intakes here in saudi arabia for yaris sedans
Old 06-14-2010, 07:52 AM   #8
MUSKOKA800
MUSKOKA800's Avatar
If you cannot locate a CAI for your 1.3 you install a K&N drop-in filter after swiss-cheesing the bottom of the airbox. The effect should be similar, just not as sexy.
Old 06-14-2010, 09:01 AM   #9
syntax
syntax's Avatar
i will try first on a used oem airbox, i'll try to remove or mold it to make look like a CAI or short ram then plug an aftermarket filter, would it have the same effect?
Old 06-14-2010, 09:38 AM   #10
as long as everything is sealed up nicely it should be OK!
Old 06-17-2010, 07:37 PM   #11
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
yes it does , i did it and it worked .... it fits exactly supposing ur talking about the typhoon SRI
bas el fr2 hyb2a baseet awii
JapRulezz is offline   Reply With Quote
Old 06-17-2010, 08:06 PM   #12
severous01
you can order any piece you want from k&n, call customer support
Old 06-21-2010, 01:24 AM   #13
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
I use AFE intake on my 2NZFE and its 100% bolt-on
ricepower is offline   Reply With Quote
Old 06-21-2010, 02:51 AM   #14
syntax
syntax's Avatar
@ du2efs how did you order it from AFE? what is the part number? thanks
Old 06-21-2010, 07:33 PM   #15
JapRulezz
JapRulezz's Avatar
if u live in KSA i think u should go with oiled type filters
Old 06-29-2010, 01:48 PM   #16
syntax
syntax's Avatar
can i use an aftermarket drop in filter instead? would that free up some much needed power in the midrange?
Old 07-15-2010, 08:23 PM   #17
JapRulezz
JapRulezz's Avatar
is yours 1.3 or 1.5 ?
Old 07-21-2010, 04:49 PM   #18
syntax
syntax's Avatar
@jap i have a 1.3L
F/S K&N CAI, 6k HID h4 kit, Apexi RSM AzNguy Items for Sale by private party 34 10-14-2012 10:17 AM
Just installed K&N CAI tambasher Performance Modifications 27 05-04-2010 08:43 PM
FS: K&N CAI, C-5 Spoiler frownonfun Items for Sale by private party 26 02-08-2010 12:28 AM
FS: BOMZ CAI posaunemeister Items for Sale by private party 8 10-03-2009 02:02 PM
TRD CAI & TRD Qiuck Shift Polar Items for Sale by private party 7 08-02-2007 06:03 PM
