Old 06-15-2010, 07:04 PM   #1
llcooljayce
Drives: 2007 Yaris Sedan
Yaris battery problem ... Stuck in a parking lot ... HELP!
Hey guys,
Writing this sitting in a dead Yaris. 2007 sedan. Here are the symptoms:
1. Battery dies unexpectantly after driving in it for about 10 mins. Shouldn't be a dead battery or alternator cause I just stopped the car for 5 mins max.
2. Has happened before where I would then open the driver side door and then close it. Magically the power returns ... WTF?
3. Toyota had been advised but couldn't recreate the problem.
Any ideas?
Battery's indicator window shows it is charged ...
llcooljayce is offline   Reply With Quote
Old 06-15-2010, 07:06 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Checked the battery terminals to make sure they're not loose?
Old 06-15-2010, 07:07 PM   #3
llcooljayce
They are on there solid ...
Old 06-15-2010, 07:20 PM   #4
SignPirate
SignPirate's Avatar
Drives: 2007 Blue Yaris
Follow the ground from the battery.... is it bolted securely?
SignPirate is offline   Reply With Quote
Old 06-15-2010, 07:22 PM   #5
SignPirate
SignPirate's Avatar
Look for something around the door.. skinned wire shorted or pinched
Old 06-15-2010, 08:34 PM   #6
Do you have power door locks and windows? If so, try pulling the 30A Power, 20A RL Door and 20A RR Door fuses one at a time (from the under dash fuse panel).
Old 06-15-2010, 08:50 PM   #7
karr1213
4-Banger N00b
karr1213's Avatar
Drives: Aisubeki '09 Yaris.
Do you know if the battery even has a charge? Time to drag out the handy dandy volt meter.
karr1213 is offline   Reply With Quote
Old 06-16-2010, 07:52 AM   #8
MUSKOKA800
MUSKOKA800's Avatar
I once had the same symptom in a Mustang. It turned out that the negative battery post was loose inside the battery casing. When the engine compartment and battery was hot (after driving) the car sometimes was dead. No crank. Not even a soleniod click. I never had an issue during cold starts.
Replacing the battery solved my problem.
Old 06-16-2010, 09:44 AM   #9
yaris2010RS
yaris2010RS's Avatar
had it happen to a friends ford, he would drive it and all of a sudden it would.... well....become a ford (found on road dead). turned out replacing the connectors to the battery was the issue. they seemed tight and u couldnt move them but according to a mechanic they stretch and wear out and u cant tell.... lol.
temp fix, find a good thin steel or copper nail...or a few and hammer them in between the connector and post.
Old 06-16-2010, 07:18 PM   #10
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
any info on what happened? was it a shorted wire?
Yaris Clutch problem pung General Yaris / Vitz Discussion 2 04-11-2010 03:16 PM
Sweet Wal-Mart Parking Lot At Night The Architect Photo-Video-Media Gallery 12 10-29-2008 11:16 PM
