Old 06-17-2010, 11:47 PM   #1
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
tigertecs...hmm
Hello everyone!
So I got my tigertechs installed maybe 2-3 months ago....I started to notice that the back seems a bit lower than the front, so I figured I had too much junk in my trunk and decided to take out my subs, (thought that would make a difference).
Obviously not, could it be that the springs were installed the wrong way or was there something else that should of been done. Friends of mine did it and I took it to them twice to check it out...but all was well.
I'm really hoping that I could get some advise, if nothing helps I may just go back to stock (which I reallly don't want)...
PLEASE HELP.
msfire671 is offline   Reply With Quote
Old 06-18-2010, 12:38 AM   #2
got pictures from underneath? Need to see if they weren't installed backwards.
also, hatchback or sedan?
Old 06-18-2010, 07:04 AM   #3
msfire671
msfire671's Avatar
sedan...ill get some pictures soon.
Old 06-18-2010, 09:16 AM   #4
I think everyone who installs aftermarket springs in the sedan/vios gets a little lower height in back. This seems to be true regardless of the brand of spring. I believe there is a thread for spacers to fix the problem.
Old 06-18-2010, 10:15 AM   #5
Kamikaze1987
Drives: 2007 Yaris Sedan S
I agree with the drop issues on the rear of the sedan... i got a drop of around 2.5" in the rear with the tigertec/tokico blue combo... probably gonna have to remove my hub spacers cuz im rubbin my 17s on almost every bump :(
Kamikaze1987 is offline   Reply With Quote
Old 06-18-2010, 10:46 AM   #6
more weight over the rear wheels w/ a sedan. 2 feet more of body overhanging the rear wheels...not sure why everyone is surprised when lowering springs for the yaris drop the sedan more in the rear than on a hatchback - - all the springs say they're universal for the yaris, but i think were designed on/for the hatch?
Old 06-18-2010, 12:01 PM   #7
^ Yeah they probably were, but it's still a problem I'd like to attend to. I can't find the thread about the spring spacers. Maybe we should make some
Old 06-18-2010, 12:19 PM   #8
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Can't you buy something that sits under the rear springs to raise the height
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 06-18-2010, 01:25 PM   #9
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
id like the ride height adjuster thing that coilovers have, The twisty ring thing....its early and iv been study for an accounting exam, cant get my mind to use words correctly.
Check out my Build thread:
Old 06-18-2010, 02:12 PM   #10
Arkhangel
Arkhangel's Avatar
Well its a bit confusing for some of us since we keep hearing the sedan is lighter then the Hatch...
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 06-18-2010, 02:26 PM   #11
lighter overall? maybe
but just look at the shear number of components supported by the rear suspension...
Old 06-21-2010, 08:53 PM   #12
33OH
Drives: '08 Yaris
Spring stabilizers will raise it a bit, and also make it stiffer. Or you can do what I did and lower the front to match the rear with spring compressors. (the leave-in, mini kind.) Both options are under $20.
Tigertecs and Bump Stops hatchblack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 03-31-2010 10:02 AM
Which is more performance oriented...Tein stechs or TigerTecs? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 12-30-2009 10:40 PM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
hmm quick help Klinton Performance Modifications 4 04-16-2009 07:49 PM
hmm LEGATO`` Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-21-2009 06:04 AM
