Old 06-20-2010, 11:03 AM   #1
HK47
Drives: Toyata Yaris
Major issues...
After 40 years as a car owner, I have to ask: Are cars not made like they were back in the old days?!
I've had a Triumph Herald 1200, Mazda 1300, Mitsubishi Colt and now a Yaris.
During one year I have had the following problems with my Yaris:
1st Accelerator can get stuck
2nd Wheel nuts are rusting
3rd Rear brakes are rusting solid
4th Rear brakes subsequently howl and can not be repaired
Couldn’t one just get a good old VW that runs and runs without any problems?!?
HK47 is offline   Reply With Quote
Old 06-20-2010, 11:26 AM   #2
Billiam
Drives: '10 White Yaris 4D LB
Nice 1st post.
Old 06-20-2010, 11:30 AM   #3
tomato
tomato's Avatar
hmmm.. the vast majority of us on this board are not having any (of those) problems with the Yaris.
but you're right, they don't make cars (or anything for that matter) like they used to. Also, nowadays, you can actually get further than 15 miles with a gallon of gas.
Old 06-20-2010, 11:46 AM   #4
Kongo-Otto
Drives: '09 Yaris & '10 Auris
1. Did it stuck? Thats very rare.
2. Erm ... are you serious?
3. & 4. Disc Brake? Common issue since they are kind of oversized. Use the handbrake if safe to "polish" and "clean" the rear disc brakes. I do this from time to time. If the brakes make weird sounds check the pads and sand the edges of the pads. Re-Install with ceramic based antiseize on the back (!!) of the pads.
Drum brake? Sand the drum and paint it with heat-resistant paint. Get the inner side of the drum cleaned with brake cleaner.
Old 06-20-2010, 12:23 PM   #5
MadMax
MadMax's Avatar
No, they are made better! Most of the cars from the 60s and 70s weren't made to last past 60K miles; you can easily double or even triple that with your Yaris.
Secondly, I am not sure about The Netherlands but I lived in Belgium and I recall them salting the roads a lot during the winter. If that's the case in your country, you need to be especially careful to clean your car as much as possible as that is probably the reason for your corrosion issues.
Lastly, as a previous owner of several VWs, they are great cars but the last thing I would brag about them would be that they never have any problems! Mine were very dependable and a joy to drive, but they did require a lot of maintenance! I'd still own one, but in the long run I expect the Yaris to be a lot cheaper to own and operate!
Old 06-20-2010, 02:04 PM   #6
ddongbap
I think you guys got trolled.
Old 06-20-2010, 03:55 PM   #7
bronsin
bronsin's Avatar
Did you own a car then? My 1974 beetle went a total of 250k miles in eight years. The first ting to go bad was a joint in the wiper arm system at 80k miles. Cost $3 to fix it. The engine was rebuilt once. Everything else including the brake drums went the distance.
The beetle was a primative car by todays standards. I would take a new one of those over a Yaris in a heartbeat.
Old 06-20-2010, 05:36 PM   #8
tomato
tomato's Avatar
yeah, that crossed my mind too.
oh well. No biggy
Old 06-20-2010, 06:03 PM   #9
brg88tx
Drives: 07 Yaris Sedan, Auto
op is a lying troll/competitor shill
brg88tx is offline   Reply With Quote
Old 06-20-2010, 08:17 PM   #10
Kal-El
Kal-El's Avatar
These trolls are getting really sickening.
Problems with the Yaris are virtually nonexistent. And today's cars are built 10 times more reliable then they were before 10 years ago.
Double or triple 60k is a big understatement. Even a Chrysler product (among the worst quality cars) can go 200,000+ miles. A Yaris can go over 500,000 miles. We've already seen one go well past 400k with only one minor repair.
Old 06-20-2010, 08:32 PM   #11
Billiam
What we need is a big ol' bucket of industrial strength Troll-Be-Gone. The mods could have more fun playing with that instead of worring about deleting my posts!
Old 06-20-2010, 08:59 PM   #12
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I used to have a spray can of Bullshit Repellent. Need some more.
Old 06-20-2010, 09:31 PM   #13
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
If this were true, then i would suggest you remove your car from your ocean based parking space. I would also suggest that you are full of crap, since there have been no reports of a stuck accelerator on a Yaris... maybe you should troll the prius forums?
Old 06-20-2010, 10:58 PM   #14
Hershey
these cars are not perfect .
Old 06-20-2010, 11:07 PM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
^^ Is there such a thing?
Old 06-20-2010, 11:23 PM   #16
tomato
tomato's Avatar
that wouldn't be the post about counseling another forum member to go play with a certain body part, now would it?
You're welcome.
Old 06-20-2010, 11:47 PM   #17
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Perhaps this?
Stove is offline   Reply With Quote
Old 06-21-2010, 12:26 AM   #18
Hershey
that overall mileage for your 2010 5 door doesn't seem all that great . You must have something wrong with your YARIS .
