Old 06-26-2010, 04:11 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Replacing fuel filter
F.I.Y.
Recently I replace my fuel filter for my yaris sedan and I was amazed (i think syntax to was amazed) when we found out where the fuel filter located.
Check the picture below, it is under the rear passenger seat of your car.
duke_afterdeath is offline   Reply With Quote
Old 06-26-2010, 04:26 AM   #2
syntax
syntax's Avatar
Nice info ito duke ! i was surprised also sa location ng fuel pump at filter, i thought you have to raise the car and removed uderneath, at least ngayon alam na natin kung saan, at ano mga symptoms kapag kailangan na palitan ung fuel filter.
nu nga ba un mga nakikita mo problema kaya napalitan ang fuel filter at ung nabangit nila tungkol sa paglilinis ng engine bay ?
Old 06-26-2010, 04:35 AM   #3
duke_afterdeath
oo pala,, kapag naka idle ka parang mamamatay ang makina nagba vibrate sya mararamdaman mo din sa kuryente sa AC sumasabay ung power kapag nag gas ka..symptoms din ito ng baradong trottle,, dahilan nman ng bardong trottle, iwasan daw sa carwash spray ng tubig diko alam futher reason pero un lang nakuha kong info, maybe the water somehow gets into the trottle...
tapos ung paglilinis ng trottle si sintax na bahala kc sya ung nanonood while nililinis kc nasa loob ako ng car, hahaha..
Old 06-26-2010, 04:37 AM   #4
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Kayo na ba mismo nagpalit nung filter? How much was the cost?
rye7jen is offline   Reply With Quote
Old 06-26-2010, 04:43 AM   #5
duke_afterdeath
rye ung filter nasa 290 SR set sya kasama ung canister (makikita mo sa picture na malaki white round plastic).. tapos ang nag install mekaniko na, meron syang special tool na pinangbukas..
Old 06-26-2010, 04:55 AM   #6
syntax
syntax's Avatar
@ rye ung carbo cleaner ng ACDelco ang ginamit habang nag ggas si duke, spray lang sa loob ng throttle body, mga apat na spray habang nag ggas si duke,
baka mag masamang epekto in the long run ang lagi nababasa ang engine sa pag carwash, lam ko mahilig si rye dun at si duke din, sabi nila blower na lang at punas punas na lang, or gamitan din ng penetrating oil spray. then punasan.
eto nga pala ung ginamit na tool para maalis ung fuel pump at filter assembly.
Old 06-26-2010, 05:03 AM   #7
duke_afterdeath
boyscout talaga itong si syntax, meron na agad picture ng tool
Old 06-26-2010, 05:41 AM   #8
syntax
syntax's Avatar
wahahahah ! boyscout ba? kasi ala rin ako dati idea dyan kung ano itsura ng pang tanggal nun, kaya post ko dito para share sa mga kayaris natin kung ano ung pang tanggal dun.
Old 06-26-2010, 05:46 AM   #9
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax, don't worry tol, once or twice ko pa lang ata napalinisan ang engine bay, last na palinis ko eh yung nag-Yaris meet tayo. Alam ko pinetrating oil spray lang ang ginamit nila sa engine, di sila gumamit ng tubig. Pero thanks for the reminder, buti na lang hindi ko pa lagi dinadala sa carwash yaris ko.haha!
@duke, ilan km na ba Yaris mo? I mean according to syntax, ano nga ba yung mga symptoms na mararamdaman?
Old 06-26-2010, 05:57 AM   #10
duke_afterdeath
45k na yata takbo ko...
Old 06-26-2010, 01:35 PM   #11
trebparadise
Drives: sedan yaris y
Good Info. minsan pa naman isa sa mga dahilan kaya tumitirik ang sasakyan ay ang maruming fuel filter.
trebparadise is offline   Reply With Quote
Old 06-28-2010, 01:59 PM   #12
duke_afterdeath
tama yan treb,,, isa papala hanggat maaari wag nanating hintayin mag blink ung gas indicator before tau magpa gas,, masama daw sa pump... bakit kaya
Old 06-28-2010, 03:43 PM   #13
trebparadise
ganun ba.. Naku, two times pa manan na nangyari sa akin yan. salamat sa info bosing.
Old 06-28-2010, 11:31 PM   #14
syntax
syntax's Avatar
@duke kaya hindi dapat nabblink na ung gas kasi ung fuel pump ay pinapalamig ng gasolina natin, kung napansin mo ung puting assembly ay nakalubog sa fuel tank natin.
Old 06-29-2010, 03:29 AM   #15
duke_afterdeath
@syntax, oo nga pala, so kung konti na lang ang gas dahil nga nag bblink na sya di na mapalamig ng gas ang pump kc di na sya nakalubog,,, un pala ung pinaguusapan nyo ni eddie (mekaniko) bc kc ako that time taking pix hehehe...
Old 06-29-2010, 05:36 AM   #16
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
^ Na-experience ko na 'to once. good thing may malapit na gas station sa location namin. Worried din ako nun nung nagbblink na, was thinking about the disadvantages at meron nga. Thanks sa info guys!
Old 06-29-2010, 09:04 AM   #17
syntax
syntax's Avatar
@ duke oo ung nga pinag uusapan namin nung mekaniko, dahil nasabi ko kung lahat ng assembly ng motor pump at filter ay iisa lang, meaning ung motor ay nakalubog sa gasolina natin, which means ito ang nagpapalamig sa fuel pump.,
kapag nasa 1/4 na u ng gasolina ko, nagpapagasolina na agad ako..
Old 06-29-2010, 09:44 AM   #18
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
^ ako syntax magmula nung nangyari yun pag nakita kong half na pa-refill na agad ako. BWahahaha!
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
