Old 06-28-2010, 05:52 PM   #1
sex
sex's Avatar
Drives: 09 5DR
looking for picture of the AA2 connector
If anyone happened to take a picture of the interior main fuse panel with the AA2 connector on top, I'd appreciate a link.
I'm planning to tap into the horn wire at #17 in my 09 LB but I think I might have the wrong connector.
Old 06-28-2010, 09:06 PM   #2
It's the connector below. Pin 18 is the green one, one the right (one pin over from the end). Pin 17 is the blank one next to it, and the end. The horn is pin 18 on a liftback and pink 18 on a sedan. The routing of this feed is so strange that I rang it out all the way from the horn connector to there to make sure.
The horn fuse is in the under hood fuse panel. That 10A feed splits and one leg goes through the relay coil (the horn relay is built into the block with the horn fuse) to the steering wheel, where the horn switch grounds the circuit to honk the horn. The other leg goes through the relay contact to a connector on the bottom of the under hood fuse panel, from there it goes through the firewall, under the dash (to connector AA2), and then back out to the bottom of the under hood fuse panel, through connector BA1, and then out the top of it to the horn.
Old 06-28-2010, 10:04 PM   #3
sex
sex's Avatar
Drives: 09 5DR
Thanks Scott. So much for the 07 EWD...
The plan is to tap into this wire and add a toggle switch, which will drive a relay. That relay will be used switch a new line to feed a pair of horns.
This way I keep the stock horn for friendly beeps and use the louder ones with discretion.
Old 06-28-2010, 10:17 PM   #4
That's a bear to get at, as it requires having the dash off. I would switch on the control side instead. You can cut into the wire that goes to the horn switch, which is way more accessible on the bottom of the steering column.
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 12:29 PM
YARIS/VITZ 2006 - USB Connector on Dashboard or Console jojozep2008 In Car Entertainment + Electronics (audio / video / alarm) 8 04-19-2011 11:41 AM
What is that connector for? (in the door) kac DIY / Maintenance / Service 2 05-20-2010 05:03 PM
Scanguage II connector pins defect?? auxmike DIY / Maintenance / Service 21 09-14-2009 11:59 PM
AUX connector for Yaris 2006 quemaculo In Car Entertainment + Electronics (audio / video / alarm) 1 08-27-2006 09:14 PM
