Old 07-01-2010, 12:02 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Question about washing or washing fresh new paint job
So car is back from the bodyshop finally this time the paint is closer. Not perfect but ill live with it. My question is i have heard on new paint you should not wax it. Suposidly the paint needs to breath in order to fully cure. Wax seals it in and it can take years then to completely cure. I noticed the shop did put wax on it when i picked it up. I am wondering if i should strip the wax off.
Old 07-01-2010, 12:35 PM   #2
Brian
Brian's Avatar
You can wash it but no wax for 30 days.
Old 07-01-2010, 12:50 PM   #3
YarisSedan
Hmmmm maybe i should wash my front end with dish soap then to strip the wax they put on.
Old 07-01-2010, 01:23 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Dont use dish washer soap, and dont wax it yet, like Brian said wait for a month to go by, then you can give her a waxing. You need to let the paint to settle down first, patience my dude its worth the wait, trust me I had my door painted for an accident that happened with my wife, and thank god for the sun down here it a perfect match, just let the sun do its work and it will blend in, then you can wax her down, holla at your boy.
Old 07-01-2010, 02:39 PM   #5
Brian
Brian's Avatar
If you wanna wash it use the Meguiar's car wash. Thats what I used on my fresh paint. Dish soap is too harsh. Dry it with a high quality micro fiber towel to prevent clear coat scratches.
Old 07-01-2010, 05:34 PM   #6
YarisSedan
The only reason i mention dish soap is because the bodyshop already waxed it. So i want to strip off the wax to help the paint cure better and faster. They just happen to be doing road construction all over my area so i know little rocks will easily knick the soft paint.
Old 07-01-2010, 05:44 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Wax is a thin film and isn't impervious to the solvents in paint. Sure it slows down the release of the solvent fumes a bit, but it'll still cure.
Old 07-01-2010, 06:19 PM   #8
spleeping prophet
spleeping prophet's Avatar
Drives: 2005 Vitz RS
lots of sun, let that paint fully cure and like another member said, use some of none abrasive (sp?) towel.
And and make sure the sponge you use is clean, i've fuced up in the past by using a dirty one and ended up leaving small scratches in the paint.
spleeping prophet is offline   Reply With Quote
spray paint removal of cars paint job big lo Wash, Wax, Detailing, Exterior Repairs 15 06-19-2010 05:15 PM
Flint Mica paint question Pitt Yaris General Yaris / Vitz Discussion 17 05-16-2010 05:13 PM
Interior Paint Question Qilene15 Cosmetic Modifications (Exterior/Interior) 15 04-23-2010 04:31 PM
wanting to paint my dash flat black but have a question removing knobs YarisSedan DIY / Maintenance / Service 0 07-08-2009 02:55 PM
Paint job eflb55 Cosmetic Modifications (Exterior/Interior) 3 12-17-2006 08:22 PM
