Old 07-04-2010, 12:20 PM   #1
MarkBen
Drives: 2007 Yaris LB Met. Meteorite
AC Fan not running
Today my AC stopped working, and I was wondering if there was an easy fix before taking it in to the dealer. There is no noise whatsoever when turning the AC on (or heat for that matter). And I checked a number of fuses that I thought might correlate to the problem just from looking at the manual. Any ideas?? Thanks..
MarkBen is offline   Reply With Quote
Old 07-04-2010, 02:46 PM   #2
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
AC Not working
Originally Posted by MarkBen View Post
Today my AC stopped working, and I was wondering if there was an easy fix before taking it in to the dealer. Any ideas?? Thanks..
You might want to check the fuse for the AC before driving to the dealership. You changing the fuse will be much cheaper then if they did it for you.....
bobolinko is offline   Reply With Quote
Old 07-06-2010, 09:54 AM   #3
MarkBen
Thanks. I did check the fuses that said they were AC related, but they were all good. I noticed the coolant resovoir was low and filled it, and apparently that was the problem. This morning the fans ran and AC is working fine. Go figure.
battery light stays on but running fine galactus Mid-Atlantic 13 08-15-2013 09:50 AM
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
Noisey fan rjh0116 DIY / Maintenance / Service 1 12-13-2008 03:37 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
